When Oven turns off so does oven pilot
Hi there, it is possible of the pilot being too close, but usually does not have that effect, unless the pilot is too small. But if you replaced the pilot, it should be clean, so next I would look at the gas pressure, if this is too low, the flame won't have proper burning speed, and strength, and could get drawn out. The control valve may be of the type that has a regulator built in, you may need someone skilled at gas pressure measuring, to do this, your gas supplier, appliance professional, plumber, should be able to do this.
Let us know, and thank you.
We installed a new pilot light in to our garland oven no gas commes thru.
if we install it the way we got it if i blow air to the out it gos thru if i blow at the in part noyhing gos thru.
Wat do i do wrong. willy from costa rica
