Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Supply tube Can you just pull the water supply tube out of the back of the ice maker
    President:
  • 1,304 Answers
The water fill tube can be removed but from the back of the fridge,
disconnect the water line
turn 1/4 turn and pull
Posted on Oct 03, 2009
Testimonial: "this was a fast reply and every helpful!cant thank you effect.thanks"
Ice maker stop working
Is ice maker not working, do you mean it has no power at all.Then its faulty control board.But if there is power to ice maker and its not making ice then its not board but it can be faulty valve.---------
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
May 12, 2011 | Whirlpool Refrigerators
My ice dispenser dispenses water but is not making ice.
May 03, 2011 | LG LRSC26920TT Side by Side Refrigerator
The ice maker is no longer filling with water
Apr 29, 2011 | KitchenAid (KSRD22FKST) Side by Side...
I have a side by side refrigerator and ice maker will not produce ice anymore
Apr 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My icemaker has stopped working. It will come out, but the icemaker is no longer filling with water.
Either the water filling line is clogged or blocked or the water inlet valve is faulty. Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- You can get required parts from sears part direct online site or from repairclinic.com site.
Apr 27, 2011 | Refrigerators
Ice maker not producing any ice cubs
Apr 26, 2011 | Fisher and Paykel Active Smart® E522BR...
While we can get water dispensed from the door, the icemaker has stopped making ice.
Apr 26, 2011 | General Electric GSHF5KGX Side by Side...
Ice tray won"t fill with
Apr 26, 2011 | GALAXY Microsystems 25.4 cu. ft....
How to reassemble ice dispenser parts od kenmore model 106.5706*602
Clean out the new ice maker with warm soapy water.
Ensure that the floor surface under your refrigerator is level. If the floor surface under your refrigerator isn't level, you can place shims under the legs of the refrigerator to fix the uneven surface.
Turn off the main water supply to your house.
Clear the water line by running the faucets until the pipe clears.
Screw the copper supply line's connector to the house's cold water connector valve. Use an adjustable wrench to tighten the connection.
Slide the compression sleeve and nut onto the other end of the copper supply line. The compression sleeve and nut will wrap around the outside of the copper supply line.
Bend the copper supply line to fit into the water line inlet casing located on the back of the refrigerator. Leave slack in the line so that the refrigerator can be pulled away from the wall or cabinets. The water line inlet casing is a plastic bracket used to hold the copper supply line in place so that there is no pull on the tubing's connection. It is the larger of the two plastic brackets located on the back of the refrigerator.
Insert the compression sleeve located around the end of the copper supply line into the ice maker connector. The ice maker connector is already installed on the back of the Maytag refrigerator.
Tighten the nut over the connection between the compression sleeve on the copper supply line and the ice maker connector with an adjustable wrench.
Attach the water supply tube clamp to the water supply line by clipping it into place. The water supply tube clamp is a plastic bracket located on the back of the refrigerator that holds the supply tube so that it doesn't rattle and become disconnected. It is the smaller of the two brackets located on the back of the refrigerator.
Turn on the main water supply.
Check all connections for leaks.
Position the drain hose located on the back of the ice maker over your floor drain. Use a PVC pipe if you need to redirect the drain hose flow so that it falls over the floor drain. The PVC pipe should not touch the drain hose and should have no low point where the water can settle.
Plug the ice maker into a 3-prong grounded outlet.
Feb 05, 2011 | Kenmore Refrigerators
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
