Question about GE Spacemaker JVM1640SJ Microwave Oven
Replacement of thermistor
What is the easiest way to replace the thermisto. Is there a diagram that explains the procedure?
    President:
  • GE Master
  • 1,922 Answers
Its on the side of the magnetron tube, remove the outer cover,MAKE SURE to DIS-CHARGE the HI-VOLTAGE capacitor, its round appx. 3/4" round with 2 tab connections for wires remove 2 small screws and replace
Posted on Oct 13, 2009
Ge spacemaker xl jvm1340WW error message e2
please make this step , use the multimeter, and fix it. Merry Christmas.
F2 Oven cavity thermistor closed Check oven thermistor for continuity. Replace if zero or infinite ohms.
Dec 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
F2 error message
please follow this step , use the multimeter and fix it. Merry Christmas.
How do you replace a thermistor
go to the next page, remember this is your question how to replace thermistor.use the common sense. God bless you
Sep 16, 2012 | GE Microwave Ovens
Sharp convection microwave temperature is off on the convection side.
this is the thermistor is time to replace,if the fan of the oven is working,also couse this problem.
Jul 13, 2017 | Sharp R-9H84B Microwave Oven
I need instructions for the replacement of glass cooktop. I have the spare part with me
The following link explains step-by-step how to replace a glass cooktop on MOST ranges:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
If you have questions about any of these procedures, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | Microwave Ovens
Where is the thermistor
Many Microwaves do NOT use a thermistor, as such, they do however have thermostat type electronics, what you need to do is get a service manual, this will have a schematic diagram.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/280381a25d6e9bd885256e380058a213?OpenDocument
Above find a service manual for a generic service manual.
Jun 03, 2010 | Microwave Ovens
Turntable will not turn housing seems to be loose
This is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
If the model number is correct, the part number is WB26X10135. You may also consider replacing the turn table shaft (coupler), part number WB06X10564. You can purchase replacement parts at the following websites: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back and let me know. I hope this helps you.
Dec 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
NTC cover message after replacing fuse in my whirlpool microwave MH1170xsb
The "negative temperature coeffecient" (NTC) thermistor was left unplugged after reassembly or it is defective.
It is the hood thermistor, and should be plugged into connector P4 on the circuit board.
I think it should be at the bottom of the board, on a little tongue-like protrusion, as shown in the attached photo.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here (just enter your model number).
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 16, 2009 | Whirlpool MH1170XS Microwave Oven
I have power to the plug, but nothing to the unit when it is plug
First unplug the unit.
This can be caused by one of two possible conditions.
You may have blown a fuse inside the unit or the thermistor may have blown. You can check them with a simple ohm meter. You will have to take the covers off to access the parts. The thermistor is located at the air outlet. This thermal resistor (thermistor) is designed to open if heated too hot and shut power to prevent fires. You can see a diagrams at;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260464
It's usually the thermistor.
The parts can be purchase at electronics stores like Radio Shack.
Mar 30, 2009 | Whirlpool GH7155XHS Microwave Oven
Where is the fuse on a Frigidaire GLMV169D
This problem is almost certainly caused by the thermistor failing. The thermistor is located at the
air outlet of the unit. This is a thermal resistor that cuts off the electricity to the unit if it overheats. Sometimes it can fail from age.
Go to;
and enter your unit number. You can even get diagrams in the left-hand corner screen.
Replace with same value thermistor.
Also see if a mini manual in hidden behind the control panel.
Mar 20, 2009 | Frigidaire GLMV169D Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
85 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
