Question about JVC GR-D250 Mini DV Digital Camcorder
Doesn't record Dare Sir - Hi we have problem when we want to press the record button it doesn't record anything and the ward pause appear on the screen, can you help us to find out what's wrong with it please . Thank you
Camera is in safe guard mode want you to remove and replace battery still in safe guard mode
Posted on Dec 21, 2007
Washer won't run just makes humming sound
hi the fault may be down to the brushes on the motor
regards
shaun
Nov 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi ! .I recorded my voice in the MSI 527. How may I play that record ? What button must I set to visualize and ear the archive. Thank you very much Marisa
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
Jun 26, 2011 | MSI MEGA Stick (256 MB) MP3 Player
Dish Network controller doesn't work if you happen to pause or stop when the screen is black or on a dark picture. You have to turn TV and control box off then back on to regain controller.
falcondan
The remote works fine other than this stated problem? What type receiver and TV do you have? Do this just began occurring? Have you checked the batteries to make sure they are fresh? Is this on TV 1 or TV 2? One thing you may try is readdressing the remote to the receiver.
Remote: All Other Remotes
  1. Go to System Info screen (press Menu button 2 times on remote).
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Jun 25, 2011 | DISH Network IR Remote Control
How do i use the micophone
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
Jun 20, 2011 | SanDisk Sansa Clip MP3 Player
I have the mp3 and just wondering how long you can record voice on it.. ?
2. Select Voice
6. Press '<< button to return to the Voice Menu.
Please leace feedback
Cheers
Andy
Jun 04, 2011 | SanDisk Sansa Clip MP3 Player
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
My computer doesn`t recognize my ipod?
Hi, try these steps
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 02, 2009 | Apple iPod nano
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
104 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
