Question about Amana DLE330RAW Electric Dryer
LEA30AW AMANA DRYER TIMER SWITCH CONNECTION PROBLEM..
HI.
I have a problem with a timer switch connection wiring. when I try to replace the timer, because when I push the start button and it doesn't reply, so I knew the timer switch is burn out, the smoke is come up from behide the timer switch, cause I push twice the button. ok then I bough a new timer, but stupidly when I'm unplug the wire I didn't make any mark or I should take a picture while is still connect.. you know the wires colore red, white, blue, yellow, pink and more. if any one know how to connect or have any original picture please let me know. I'm really appreciated. you know is winter time in up north of Minnesota, and is pain in the a&% when you try take it to the laundry store.. once again thank you.
  • rico1064 Aug 26, 2008
    I too made the ********* mistake of not marking were all the wires go on the timer. Now I am stumped. Could somebody please help me, figure out what color wire goes were on the timer. Amana lga50aw. Thanks!
    David
  • Anonymous Dec 19, 2008
    wires going to timer?
  • 833 Answers
I don't have a diagram but it is possible the the first letter of many of the colors is on the plastic around the screw connectors. Have a look. Good luck.
Posted on Dec 21, 2007
Why would my Amana washer not do anything but fill up with water. Nothing will function at all on all the cycles but the fill. It doesn't even click on the timer when you try to set to any setting exc
Hi Kirby
First... Caution
Because your dealing with water & electricity it can be lethal to fiddle around inside. That said...
Washing machines are controlled by a master timer unit, usually mechanical, but rotated by an AC Clock motor. If the timer is not getting voltages to the various Switches around the "timer unit" or "clock motor" then the individual selected functions won't work.
Manually Rotating to a particular function then Activating the On/Off Push/Pull switch should start things happening even if timer motor is dead. So
If your OK with AC electrical goods then open it up.
Connection wires may have fallen off or something simple. A multimeter is your best friend here. Look for the big rotary clock behind the main control dial. Listen for the clock motor running. The main Push in & out Button is the On / Off switch. Check that its got AC on the input wire & switches across to the other wire when the knob is pushed in / out. This may be the problem...
You can always call an appliance repair technician!
Good Luck
Nov 19, 2014 | Amana 3.2 cu. ft. Top-Load Washer
I have amana dryer lea30aw that will not do anything trying to see how to check the timer control assembly . I have checked all other things power in, thermal fuses, switches coil etc, but all test good....
u can find out how to check ur timer motor with an Ometer by going to youtube and putting in ur model and type. its not that difficult to test there is no by passing it sorry
May 05, 2014 | Dryers
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Amana ALE643RBW Dry will not start. I checked the thermal fuse and the high limit thermostat both read 0 to 4 back to 0 ohms. It was jumping around back and forth. Checked the heating coil it read 10...
Hello Dale,
Having checked the thermal fuseto be good i will give you a partial list other things that could make the dryer not start
start switch
door switch
timer
circuit breaker, use your meter set to volts ac and check for 240 vac at the outlet,if 240 not at power outlet check for burnt connection inside outlet or bad circuit breaker
if 240vac at outlet check for 240 vac at terminal block on back of dryer where cord connects,if 240 at outlet but not terminal block replace cord , if burnt connection at terminal block,replace cord and block
finally the motor,manufactures do not publish wiring diagrams online and the only way for me to tell you to use jumper cord to check motor is find the wiring diagram inside of control panel and place one wire on the terminal indicated as neutral on wiring diagram and one wire on terminal indicated on diagram as run winding
firstly though check door switch to have contunity (0 ohms) and the start switch to have (0 ohms)WHILE PUSHING IT IN(the start switch isa momentary contact switch and will only have contunity while its pushed in)
to check timer again use wiring diagram and find chart that shows various cycles and with timer set to a cycle the two wires is says will have contunity will be indicated by a solid black line on the diagram
Good luck, Gene
Jul 26, 2011 | Dryers
I have purchased a Utilitech 7-day digital In-Wall timer and I cannot seem to install it properly. Step 2 of the instructions states that if "hot" and neutral wiring is not present you may need to add...
What you have a single pole light switch you are replacing with the timer. As you say you have 2 black wires. One black wire is the incoming power wire and the other black wire goes up to the light. On a normal single pole switch is makes no difference which of the screws you connect it to. Of course with the exception of the ground screw. Tie all the white wires back together that are in the wall box and shove them to the rear as they are not needed to make this connection. The correct connection is to connect one of the black existing black wires in the wall switch box to the black wire on the timer. Now connect the other black wire to the blue wire on the timer. The red wire is not used in a single pole connection and is only used in a 3 way switch connection, so just put a twist connector on it and shove it back in the box. To recap, connect black wire on timer to either black wire in box. Connect the other blue wire to the other black wire. Do not use the red wire. Hopefully you did not hurt the timer by connecting it incorrectly. If it does not work after setting the timer up according to the instructions you have ruined the timer by wiring it incorrectly. Hopefully no damage has been done.
Aug 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Dishwasher does not run at all,i checked the door
Hello there:
Please try these things i have posted
It doesn't work at all If your dishwasher doesn't work at all, check these: Power from the house Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be
Jul 14, 2010 | Amana Dishwashers
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
Kenmore electric dryer
HI, the door switch is malfunctioning. either the wires are loose or, the switch actuator if faulty. inspect this area thoroughly. replace the door mechanism if found to be faulty.
Jul 21, 2009 | Amana NED7200TW Electric Dryer
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
Amana DLE330RAW Electric Dryer Logo
528 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
