Question about GE Monogram ZDI15C Automatic Icemaker
Ice tray not filling and water collecting underneath refrigerator
  • ekrauss214 Oct 02, 2009
    I just notice that the ice maker model number is CAN13 and I believe the GE Monogram refrigerator model # is ZISS480DXSS. The problem is that ice tray is not receiving water and water is pooling below refrigerator.
    President:
  • 1,714 Answers
Go to the back of the frige and turn off the water line. The solenoid may be leaking and may need replacement. Look to see if you can tell if the leak is there at the water solenoid or up inside.You could have a frozen water line going into the ice maker too. Use a hair dryer and heat the back of the frige where you see the water line. Then, turn water back on and see if you get flow into the ice machine.
Posted on Oct 02, 2009
  • Craig Butler
    Craig Butler Oct 02, 2009
    Did you turn off the water line? I think the line may be frozen. Pull the back cover off and look at the water solenoid. It will have the water line going to it. See if it's leaking there or maybe from above...
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
How does the ice maker work. I see a bin on the freezer side that is empty. Do I fill it with water?
Hello
No ,please don't do that. That tray collects ice cubes. System fill is automatic. Look for a wire arm of some kind and make sure it is in down or "make ice" position .Then give it plenty of time to cycle.
Aug 16, 2011 | Kenmore 56983 Side by Side Refrigerator
Hello! I have a Kenmore refrigerator model #10656576400. It stopped making ice for a while but then started up again. Now it is leaking water and filling up the tray underneath the ice cube mold. Is it...
The first thing to check would be the water fill valve located usually on the back outside of the unit where the water line comes in, these can start leaking water slowy into the icemaker. The icemaker itself tells the valve how long tostay opened, that can be adjusted by a tech or you may need to replace the icemaker
Jun 24, 2011 | Refrigerators
Ice maker no longer making ice. A few weeks ago the water that was supposed to fill just the ice tray, didn't turn off, overflowed the ice tray and proceeded to fill the ice basket underneath. Since then...
Sounds like the water flowed enough to freeze the end of the fill tube shut. Best to prepare to replace the dual water control valve on the rear and near floor of refrigerator. If it was leaking and you should thaw the tube you need to turn the main supply of water off until replaced. Then thaw tube and replace the dual control valve. I will return with a part number providing your model number is correct, Thanks, Sea Breeze
Jan 17, 2010 | Maytag MBB1954G Bottom Freezer...
My Maytag MZD2766GES is not filling the ice maker.
there is a test button underneath the ice maker press this making sure you put a tray of some kind underneath this will operate the icemaker and go through its empty and fill cycle ,if it does not fill it will be the solonoid valve
Jun 27, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker making little ice/Leaking water on floor.
The ice trays bust be cleaned to prevent calcium build up. This will prevent the ice from froming in trays.
The overflow could be caused by the freezer not being level, or by the water fill timer not shutting of the incoming water. This will keep the water temp. too high to freeze the water. Also check the fill valve for sepage.
Feb 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Ice Maker Dumping Water into Collection Tray.
LG has a new ice cube tray that will solve this problem. The part number is 3390JA1150A The wall will stop the overflow.
Sgt 48
Feb 19, 2007 | LG LRSC26944 Side by Side Refrigerator
GE Monogram ZDI15C Automatic Icemaker Logo
57 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Sal DeAngelo
christian nielsen
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
