Question about Nokia 6600
Dropped phone now no ringtone just vibrating alert
  • 395 Answers
Switch the phone off and power it back on.
Then tap on the power switch found on the top of the phone, it pops up option and okay "General" and this would give you back your tone.
Good Luck
Posted on Oct 02, 2009
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
How to remove virbrate and keep ring tone?
Choose Settings----->Sound---->Ringtones---->Alert Type:
Supports 3 ring alert types.
Ring, Ring & Vibrate and Ring after
Vibration.
Mar 04, 2011 | LG Xenon GR500 Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/UTSTARCOM/PCS1400-_E
I got this info off of page 60 from your manual.
CUSTOMIZING YOUR PHONE VOLUME
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Ringtone
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Lg shine #cu720 will not ring and vibrate simotaneously
1. Menu -> "Settings"
2. "Audio & Ringtones"
3. "Alert Types"
4. "Ringtones"
5. "Ring & Vibration"
-Nick G
Jan 12, 2009 | LG Shine CU720 Cellular Phone
Message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Aug 27, 2008 | Samsung U900 Soul Cellular Phone
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Nokia 6600 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
