Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Red is to pink - Canon MultiPASS MP730 All-In-One InkJet Printer
    Guru:
  • 1,049 Answers
Assuming your saying that the red in your printed materials looks pink. Either you are running out of color ink, the bottom of the color cartridge is dry and caked with ink, or you have a clog of ink somewhere. Run a cleaning cycle, wipe any ink residue from the bottom of the color cartridge, and replace the cartridge if necessary.
Hope this helps.
Posted on Oct 02, 2009
INTERNAL TEMPERATURE FOR BEEF
it all depend how you want your Beef
Rare:
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
Medium-rare:
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
Well-done:
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
What color do I mix with pink to make red
You can only add red to pink to make it redder. There are three primary colors, red (magenta), blue (cyan), and yellow. All other colors are made from these three. Pink is red with white added.
Apr 01, 2015 | Office Equipment & Supplies
How can i get the words to which fuse operates what part of the car in an 06 charger???
Hi, All the Info You Need Is Detailed Below:
Front Power Distribution Center Fuses
# Amp Description
1 20 Yellow Left High Beam Headlight
2 20 Yellow Right High Beam Headlight
3 15 Dk. Blue Adjustable Pedal
4 20 Yellow Horn
5 25 Clear Headlamp Washer If Equipped
6 15 Dk. Blue Front Control Module (FCM)
7 20 Yellow Fog Lamp
8 15 Dk. Blue Park Lamp
9 15 Dk. Blue Non ABS Brakes
10 5 Orange Starter
11 20 Yellow Auto Shutdown/Powertrain Control Module (PCM)
12
13
14 25 Clear Powertrain Control Module
15 20 Yellow Injectors, Ignition Coils
16 15 Dk. Blue Powertrain Control Module
17 30 Pink Antilock Brake System (ABS) Valves
18 30 Pink Windshield Wiper/Washer
19 50 Red Radiator Fan
20 20 Lt. Blue Starter
21 50 Red ABS Pump Motor
22 40 Green Radiator Fan High/Low
23 50 Red High Intensity Lighting
24
25 30 Pink Lighting Left High Beam/Right Low Beam
26 20 Lt. BlueTransmission
27 30 Pink Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center Fuses
1 60 Clear Ignition Off Draw
2 40 Green Battery
4 40 Green Battery
5 30 Pink Heated Seat/Steering Column
6 20 Yellow Fuel Pump
7
8 15 Dk. Blue Ignition Start/Run - Start
9 20 Yellow Console Power Outlet
10 10 Red Rear Fog Lamp If Equipped
11 25 C/BRKR Memory Module/Door Locks
12 25 C/BRKR Passenger Power Seat
13 30 C/BRKR Door Module Run/Acc/Delay
14 10 Red Sentry Key/Remote Keyless Entry/Cluster
15 20 Yellow Brake Light (5.7L)
16 20 Yellow Power Outlet Trunk - if equipped
17
18 20 Yellow Selectable Power Outlet
19 10 Red Stop Lamp
20 20 Yellow Rear Wiper If Equipped
21
22
23
24
25
26
27 10 Red Airbag/Occupant Classification Module
28 10 Red Curtain Airbag - if equipped
29 5 Orange Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
30 10 Red Steering Column Module/Power Mirrors - if equipped
31
32
33
34
35 5 Orange Power Antenna/Garage Door Opener/Ignition Delay
36 20 Yellow Radio/Navigation
37 15 Dk. Blue Transmission
38 5 Orange Analog Clock/Garage Door Opener
39 10 Red Heated Mirror
40 5 Orange Power Mirror
41 10 Red Climate Control Module/Headlamp Leveling if equipped/Rear Park Assist if equipped/Tire Pressure Monitoring if equipped
42 30 Pink Automatic Temperature Control (ATC) Blower Motor
43 30 Pink Rear Defroster
44 20 Lt. Blue Audio Amplifier
Sep 13, 2012 | Cars & Trucks
1990 Chevy GMC Suburban alternator wiring
Well, according to my diagrams for 88-94 models, the alternator only uses the red and brown. There are pink-black wires that power some of the sensors and solenoids but should go to a fuse marked ECM in the fuse box.
Have you tried hooking up the harness without using the pink-black wire ?
Aug 28, 2012 | 1990 GMC Suburban
I removed an old wall oven, and the wires coming out of the wall are black, red, pink, and ground. the new oven has black, red, WHITE , and ground. Does pink go to white?
It should go to white. but to double check you should use meter to check if you have 110 Volts between the pink and the Black and 110 Volts between the pink and the red. and 220 between Black and Red
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Dec 27, 2011 | Ovens
Radio Wire diagram for 1996 nissan pathfinder
Battery red/green
Accessory green/white
Ground use chassis ground
illumination red/blue
Dimmer pink/green
Power antenna red w/silver dots
LF speaker + green
LF - red
RF + brown
RF - black/white
LR + light green
LR - black/yellow
RR + orange
RR - black/pink
Sep 20, 2010 | Car Audio & Video
Red t-shirt has run all over the wash. now have pink socks, pink backgrounds etc
did you dry any of this load in the dryer? If you did, the color is set you wont get it out.
If not rewash everything, Except the red t shirt! in the Hottest water the clothing can take. If its whites use a little bleach. you could also use a color safe bleach on colored items. You may want to divide up the load into similar items. Experiment what have you got to loose.
One time we washer a gray sweatshirt with a red sweatshirt, why the gray turned Pink! I dont know we line dried it and washed again, The pink came out.
Good luck
Oct 02, 2008 | Washing Machines
Pink hue
Remove speaker grill, manually adjust red drive untill red is normal.
Sep 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Colour issues
Sounds like your red gun may be shorted, Try adjusting the red gun down a little see it that helps.You can also switch the blur CRT socket for the red if your screen is still mostly pink then you know for sure its your red tube that needs replacement. If its mostly blue then you have a problem in the red drive circuit.
Jan 14, 2008 | Televison & Video
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
93 people viewed this question
old marine
old marine
