Question about LG Dryers
I need to change vent location from rear to side. Should I remove the back of dryer for access? If not how best do I change the vent location? I have purchased 4'' duct pipe + elbow from hardware store.
  • LG Master
  • 3,361 Answers
Turn off the power. You will have to remove the top panel. Remove the front panel. Remove the belt. Remove the drum. This will give you access to the location for side venting.
Posted on Oct 02, 2009
How do I change the dryer vent from rear to side
there is usually a pc that can be removed on the side a round plate with light soder
Jul 02, 2014 | Kenmore Dryers
Dryer not heating up
There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one.
Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch
Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.
Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.
Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3
Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design.
May 19, 2012 | Kenmore Dryers
Need to change the rear drum bearing
the top of the dryer needs to be removed.then you will find a couple of screws on the front of the dryer inside the cabinet that need to be removed,as well as the control head and front panel. there will be a small sliver vent access panel on the lower left side of the machine in the back that needs to remove in order to take the drum belt off the motor pulley.
once you remove the front panel then the drum can be lifted out and the bearing and hub can be replaced
Oct 10, 2011 | Frigidaire FEQ1442ES Electric Dryer
How do i change the high limit thermostat on a kenmore dryer # 72822
Unplug the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the back of the dryer. Loosen the retaining screw on the clamp connecting the vent to the dryer's exhaust port and slide the vent off of the port.
Remove the hex nuts holding the dryer's rear panel in place and slide the rear panel off to the side of the dryer. Locate the high-limit thermostat on the heating element housing on the right side of the dryer. The oval-shaped thermostat can be found a few inches from the bottom of the heating element housing.
Unplug the two thermostat wires by sliding them off of the thermostat's contact posts. Slide the old thermostat out of the socket on the heating element housing.
Mar 12, 2011 | Kenmore 72822Gas Dryer
Can i change which side the driver vent is located?
Hello Laurie. Your dryer allows rear vent, left or right vent. Here is a diagram which shows you all three http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE5500AYW/3048/0151200/M0606011/00002?blt=06&prst=&shdMod=
Just pull the dryer out from the wall to access the rear and sides. Joe
Thanks for choosing Fixya!
Jan 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Model 87577800 sock went thru the lint vent
The model number you have listed has the dryer vent on top of the dryer. Small items commonly fall down into the vent chute on these dryers. Articles can easily be retrieved by following these steps:
1. UNPLUG the dryer. Dangerous voltage is still present inside a dryer even when it is turned off.
2. Remove the lint screen and remove the two screws that connect the vent chute to the top panel.
3. Turn the dryer around so you can access the rear, and remove the exhaust vent hose.
4. Locate and loosen all the screws from the perimeter of the dryer back panel.
5. Remove the back panel of the dryer.
The air blower assembly and dryer vent chute are located on the left hand side (as viewed from the rear of the dryer). Remove the screws that hold the vent chute in place and you will be able to access anything that has fallen into it.
NOTE: Anything left in the vent can eventually get caught in the blower fan. So, it is important to retrieve anything caught in this area to prevent damage to the fan and to ensure the dryer ventilates properly.
If you have any questions about these procedures, please let me know. I hope this helps you.
Oct 27, 2009 | Dryers
How do I change the rear vent outlet on a Kenmore dryer to the left side?
If it's designed to change, there will be metal plate on the side that you remove and place over the back outlet (remove vent hose), then move the vent hose to the side and hook it up.
Jul 23, 2009 | Dryers
Need to move the dryer vent on LG DLE5955 to the side opening.
you shouldnt have to buy anything. remove the access panel in tne rear. remove the knockout from the side panel and relocate the exhisting hdwre.
May 03, 2009 | LG DLE5977 Electric Dryer
Change dryer vent from side to rear
Not all dryers have the facility to vent out of the side, if they can , you should see a knockout panel or cover at the side, remove this and fit vent to side.
It is important that you blank off the outlet where the hose was fitted originally.
Plz rate my answer.
Thanks..
Jan 20, 2009 | Dryers
41780042990 Kemore electric dryer
you would need to "punch out the metal" , youl also need to remove the fron tof the unit(2 screws approx 3-4 inches down form inner panel, holding front panel on, ( youll need to remove the top of the dryer( a few screws across the back of unit.) andthen disconnect the dryer belt(easiest acess through a small acess panel on lower rear of unit, pull the dryer drum out and youl see the existing ve, just a matter of attaching a 90degree elbow and running vent out the side instead of out the back. DISCONNECT POWER TO UNIT FIRST!!!!!!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
Dryers Logo
216 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
