Question about Ricoh Aficio 450 Copier
Reset the error code e-5 on a ricoh ft4522
I put new thermistors on my ricoh ft4522's fuser for an error code e-541. I understand this error need to be reset by toggling a dip switch 101-1 while the power is on. Unable to locate the dip switch. Is this the correct procedure or where is the dip switch to complete the repair.
  • kenparko Oct 05, 2009
    This reset procedure appears to do some sort of reset.
    The error comes back again. I removed the fuser and tested lamps, fuse and thermisters. All appear ok.
    I removed the rear panel and the lamps come on for about 1 second before the error kicks in and turns the voltage to the fuser off. What would be the next step?
    I was unable to find any switch on the main brd. I did get a reset procedure that does not involve a dip switch. This reset procedure appears to do some sort of reset. The error comes back again. I removed the fuser and tested lamps, fuse and thermisters. All appear ok. I removed the rear panel and the lamps come on for about 1 second before the error kicks in and turns the voltage to the fuser off. What would be the next step?
The lamp didn't turned on and ther is no light above the drum
Posted on Aug 26, 2010
  • Ricoh Master
  • 1,297 Answers
When service call E5 conditions occur,they can`t be cleared by turning OFF/ON the power switch for safety reasons.Turn ON the main switch,turn DIP switch 101-1 ON and OFF and turn OFF the main switch.Wait 3 sec and turn ON the main switch.The DIP switch is located in rear part under main cotrol board.
Posted on Oct 03, 2009
  • 68 Answers
There is no need to use dip switches to reset this error code.Providing that the thermistors are good and they have been installed correctly,here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad fusing lamp or a bad connector.
Ricoh copy, printer,fax sp100sfe all in one is showing error code sc541. how do i clear
this was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Google Translate
Nov 07, 2014 | Ricoh Aficio Office Equipment & Supplies
Error code E541
Ricoh Copier Error Code SC 541 is Fusing thermistor open problem
1. This is Open Thermistor problem
2. Thermistor connector is bad.
3. Thermistor is broken, or out of place
4. Fusing temperature -15% less than the regular input voltage
Might be a one time failure you can reset. Access service mode and reset the code then power copier off & on again. If problem goes away your good. If not.....time to replace the fuser.
Jul 27, 2012 | Ricoh Office Equipment & Supplies
Error cod sc 541
This SC-541 code comes when the fuser thermistor fails ore contaminated or poor connecton finellay power supply bord defective most of this cases we find thermistor failure first replace the thermistor 90% your problem solves- thankyou
Dec 15, 2010 | Ricoh Aficio MP 1600L Black and White...
What SC 541 is ?
sc 541 is a fuser error code. try these steps
press clear mode once
press 107
press clear/stop and hold it untill your screen changes to copy sp mode.
press copy sp on screen
off and on the machine. it shud reset its code. i am a Ricoh tech. email me if you are having difficulty. ronils_singh@yahoo.com.au
Oct 01, 2010 | Ricoh Aficio 450 Copier
Code error SC 541 ricoh aficio mp2550
SC541 is a Fusing thermistor open (center) The temperature of the hot roller remained below 0oC for 5 sec at the center of the hot roller. Fusing thermistor out of its position because of incorrect installation. Fusing thermistor disconnected or defective power supply not within rated range (15% or more below rating). Try cleaning or replacing the thermistors and reset code in service mode.
Jan 30, 2010 | Ricoh Aficio 1035 Copier
Ricoh aficio 3045 error code sc 541
Here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad thermistor,bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Office Equipment & Supplies
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code 541
hi!!!!
may be the drum is damaged
try to clean it use dry tissue
or
repkaced the drum!!!
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
SC 541
Take the fuser out and clean under the thermistors, and reset the code by entering test mode ( turn off printer hold down online and escape as you turn on printer selece 2 engine go to sp5-810 and reset this.
-Carl, please let me know if this helps.
Jul 30, 2008 | Ricoh Aficio AP600N Laser Printer
Ricoh Aficio 450 Copier Logo
676 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
