Question about Konica Minolta DiMAGE Z5 Digital Camera
Smokey pics from Dimage z5
Hi, I have a Dimage D5. The pictures are coming out smoky, as if the camera has trapped moisture.
Do you work on these cameras and can this be fixed? Is there a service center?
Thank you!
4 Suggested Answers
  • 3 Answers
SOURCE: My Dimage Z6 does not allow me to check the pictures taken.
i have the same problem. Did you get any answers? Thanks
Posted on May 21, 2008
SOURCE: Konica Minolta DiMage Z5
Hi, I have the same black area in the corner of my shot, and 'fluttering' on turning the camera on. Have called Jessops and a local independent camera shop. Both have told me that Minolta have been bought by Sony, and as such, there is no support for the Minolta cameras, which is very poor. Also, the price of cameras has come down so much over the last few years, that it is cheaper to buy a replacement than to attempt to have it repaired. A Fuji Finepix S5700 was suggested by my independant shop...does a similar job to the Dimage and costs £99. I was quoted £125 to have the Dimage looked at by Jessops! It's a no-brainer for me, although very annoying as I love my Dimage.
Hope this helps a little.
Posted on Aug 02, 2008
SOURCE: My Konica Minolta Dimage z5 won't play back photos
What size memory card are you using? I have had this problem trying to use a a 4gb card, which apparently is not compatible with the Z5. Using a 2gb card seems to alleviate the problem.
Posted on Jun 03, 2009
I require the driver for Vista O/S for the Konica Minolta DiMAGE Z5 Digital Camera.
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Jul 12, 2011 | Konica Minolta DiMAGE Z5 Digital Camera
Camera won't stay on, even with new batteries that I know are charged.
Ensure you are using alkaline batteries and that battery contacts have no oxide or liquid on top of them. If you do not use alkaline batteries this is normal.
If batteries are ok is a short circuit.
Jul 29, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Tip
I have almost identical issue with a Dimage Z5 (Konica/Minolta). I have had the...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Dec 01, 2007 | Samsung Digimax D53 Digital Camera
I see a black croissant on the picture
Z5 probably fell
Lens servo-alignment-motors might be disconnected...
Needs dismantling and check inside (dunno yet how to do it)
But you probably also experience vibrations at start
Mar 03, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
When inserting SD Card in to Dimage Z5 the camera will not read card. (''Unable to use card.) Please help.
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z5/compatibility/detail.html
Your card is probably not supported by the camera.
Jul 05, 2009 | Cameras
SD max size
I don't have any first-hand information, but you'll probably be ok as long as you stay under capacities of 2GB. The original SD specification only allowed cards up to 2GB to be compliant with the standard, so I think that pretty much every camera that has an SD slot can handle 2GB capacities.
Jan 25, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
Same SD card problem with Dimage Z5
Your Card may need to be formatted. to fix this problem:
[note- before you start, make sure that your SD Card is blank, or that the information is unimportant, because formatting your card will erase all of the information.]
1) Plug the card into your computer, if you can, in the SD slot, or use a USB - SD transformer to plug your card into a USB port.
2) After its plugged in, go to 'My Computer'.
3) Right Click on the drive its plugged it into
4) press format
5) Make sure all of the correct settings are on and start the format.
now your SD card is formatted and should work in your camera and you can continue taking pictures. YEA :^)
Apr 13, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Dimage z5
I have formatted the sd card and now I can se the picthures
Apr 04, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
The odds are you have a broken spring in the anti-shake assembly which has allowed the lens unit to shift to one side. The smudge you are seeing is the edge of the lens housing and will have a slight rounded shape. As you zoom in, you are extending the lens past this area so it no longer shows.
Feb 28, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
ANTI-SHAKE TURNED OFF
  • Switch camera on
  • Select Menu Button
  • Menu item 1
  • Use controller to move down to anti-shake
  • Use controller to move right
  • select i) Disp + Exp ii) Exp only iii) Of
Go to http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z5/Z5_OM_E_.pdf for a Z5 manual
Jan 26, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE Z5 Digital Camera Logo
22 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
