Question about Garden
Auto transmission will not engage
I have the Bob Vila 21hp 42'' lawn tractor.
I disengaged the transmisson and pushed into a garage where it sat several months.
Started up great after the layoff but the transmission will not engage.
  • 389 Answers
If you haven't already done so, reach up under the rear of the tractor and locate the release rod where it goes into the transaxle and make sure that it isn't stuck from sitting. Pull and push the release lever rod at the back a couple of times observing that it does indeed go in and out of the transaxle. You can try tapping it lightly with the lever in drive position to see if it goes in any further after you put it back into the drive position just don't hit it so hard as to bend or break anything
Posted on Oct 04, 2009
Craftsman 56" lawn tractor auto trans dose not drive forward or revers. tryed purging trans no go checked engagment rod ok, belt seems good. I can push the mower by hand as if the trans were not connected...
somehow did the little freewheel lever get pulled in the rear of the tractor to disengage transmission?..usually out is disengage and in is engaged. look around the back panel behind the rear axle for a small lever you can pull or push in.
Aug 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Lawn Tractor 17hp 42 model 917.271662 auto trans idles and bucks when cutting grass
The symptom that you are feeling is that your transmission is not fully engaging correctly. Basically you have a few different things to try depending on the trans that is on your machine. Drain the fluid and re-install new fluid, adjust your brake/clutch to make sure that you are fully disengaged and fully engaged when you release the pedal. If none of those 2 cure your issue then you are looking at a trans rebuild or replacement
May 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I changed the back tire on my craftsman riding lawn mower and now it will not go forward or backward. It runs fine.
There is a lever between the back tires which disengages the transmission so the mower can be pushed when not running. Chances are you must have disengaged this lever maybe by accident. If you push it back in, the transmission will work right again. Usually it is a wire with a loop on the end.
Aug 06, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Husqvarna lawn tractor stalls when brake is
sounds like a safety switch most likely the one for your brakes
Jun 06, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
202 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
