Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Samsung 32" tv stuck on BBC 1 with Mono displayed.
Only certain functions on the remote works. It seems to be the same problem everyone else is experiencing. I also have the same tv in the lounge but the signal is recieved via a digibox so only had to re-tune that. Funnily enough that tv is fine. Both remotes work the lounge T.V fine so it is safe to say the problem lies with the T.V and only since the re-tune. None of the solutions on here have worked as the T.V wont respond to the commands prompted on this website. The functions required are greyed out or simply wont function.
Lol
Posted on Mar 01, 2011
My samsung lcd tv stuck on bbc 1 on mono it wont go off screen
pl.see whether the other channels were locked inadvertently 2)if you have set top box remove the connection and connect the cable to antenna slot if you could change channels set top box is defective other wise tuner problem
Feb 18, 2015 | Samsung LN32A330 32 in. LCD TV
Lost all my BBC channels after tuning the TV after the Digital switch over
check that your Antenna points the same direction as everyone else in your road.
you might need a better antenna
i would re tune your freeview to see if it picks up BBC again
Hope this helps
Apr 06, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Remote code for Seiki TV 32"
The "try the Samsung codes" suggestions works. I have a ONN (Seiki) LE-24G90. The first Samsung code on the HDTV list (1019) did the trick on my Telus CISCO ST6400 remote.
Dec 01, 2010 | Televison & Video
Since last night the tvis stuck on 1 channel and it says mono on the bottom and itv is on top and wont go no other channel can be changed from remote, but the volume can be changed, so its not the battery...
You can get this fix by resetting the television
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace.
Hope this helps....
Jul 02, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung LE32R7 in DTV mode stays on BBC1
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
32" Samsung LCD HD ready TV buttons & remote malfunction
seems like your remote is getting bad and also a keyboard control board from the TV,
whats the model number?? maybe I can give you the part numbers for it
Apr 21, 2009 | Samsung 32 in. LCD Monitor TV
Sharp Aquos LC-32D44U stuck in ""Mono"
I dont know if this will work for you, but its worth a try. I had the same problem.
1. I changed to a station that was having the problem (an analog station with MONO displayed on the screen).
2. I unplugged the TV for about 15-20 minutes. (I was thinking maybe something needed to refresh, so thats why i unplugged the tv.)
3. I plugged the tv back in and voila. The station showed up as MONO then immediately swtiched to STEREO.
After that, i was able to use the AUDIO feature on the remote to actually change from MONO to SAP, etc.
Ive had my Sharp for about 5 months now, and thats the first time its happend to me. Luckily, i solved the problem...this time.
Hope it helps.
Feb 12, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Watty2c
Jan 17, 2009 | Samsung LN32A330 32 in. LCD TV
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
640 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
