Question about Vivitar ViviCam 5385 Digital Camera
Paramer incorrect ok i was trying to clean out my computer when it first happened i double clicked the shortcut on my desktop and it said "parameter incorrect" with a black browser opening it only stays open for 3 seconds at the most then shuts back down and i tried to restart my computer and when it was about to start back up "parameter incorrect" any answers on how to fix this or whats going on? thanks justin
3 Suggested Answers
SOURCE: cannot open or copy - parameter is incorrect?
The holding the sd card in a few seconds and then letting it click out to it's normal position worked for me but since my sd card reader on my eMachine is not a clickable one, I had to bridge with a Kingston sd card reader to USB. Putting the card directly into the pc gave me the same old 'incorrect parameter', 'device not ready' problems. Placing the card in the Kingston reader and then plugging it in, showed no media at all, but clicking the card into the reader and holding, while the reader was plugged into the pc, did the trick. I can now use any sd card and replace and remove files at will, including seeing properties and changing filenames of files on the card. I have the Kingston TravelLite SD/MMC reader if you want to make sure to get a 'clickable' one. Of course, you have to use care when clicking the reader whilst plugged into the machine so you don't break the usb port. I have tried many more technically posh things to solve this maddening problem but this simple thing finally did it. Thanks for the info here!
Posted on Feb 18, 2008
..wel, i solved mine.. im copying music files into a memory card like micro SD.. when im copying music.. it says.. cannot copy file.. the parameter is incorrect... then go into My Computer then Right Click the external hrd drive(micro SD),, then go to properties....then tools.. then click the Check now.. - it will check for some errors and automatically fix the errors.. :D thats it..
Posted on Jun 28, 2010
How do I access my gmail account on my computer. I have an account on my tablet.
have you signed off your Gmail on your
tablet? if not,try that first, then go to Gmail.com
onactual computer and sign in, see what happens.
maybe the computer needs an update to
download gmail to your computer. look into whatever you can.
Sep 20, 2014 | HP Computers & Internet
When i click my fifa 13 icon nothing happen and game dznt start
The shortcut may be disabled or pointed in the wrong folder
locate where the game is installed in your computer C: drive > programs, the game folder and look for the game name with exe as the extension - double click > If the game launches then delete the icon on ur desktop - right click the .exe file and create shortcut on desktop. if it does not then u may have re install the game
Aug 23, 2013 | Electronic Arts FIFA 13
The parameter is incorrect how do I fix it ?
delete the shortcut and find the exe file and right click/ hold and drag to the desktop
or right click on deskto/new /shortcut browse to file and select
Feb 25, 2012 | HP Computers & Internet
I want to know how to activate cheats in crossfire
Follow this link for the original instructions: http://www.101cheats.net/cheats/16968/PC%20-%20Windows/KKnd%202%20:%20crossfire.html
1. Go to your CrossFire folder in Windows Explorer.
2. Right click on the kknd2.exe file and select create shortcut.
3. Right click on the newly created shortcut and select properties.
4. In the target field, add "-badnews" to the end of the line. It should look something like this: "Kknd2.exe -badnews".
5. Click OK
6. Double click the shortcut to begin CrossFire.
7. While in game, press Ctrl-Tab to activate cheat codes.
Here are some common cheat codes:
CTRL-M = Extra money.
CTRL-C = Win level.
CTRL-F = Lose level.
CTRL-W = Turn on waypoint information.
CTRL-E = Turn off waypoint information.
CTRL-T = Turn off the fog of war Command line parameters.
More hints are available at the above link.
Good luck and thanks for using FixYa.
Mar 05, 2011 | Computers & Internet
Every time I try to boot up print artist platinum edition it says Print Artist Platinum has encountered a problem and needs to close. What do I need to do to fix the problem?
My parents ran into this same issue this afternoon. After a bunch of trial and error over the phone, here's the solution:
1. Go to the Start Menu and open Computer (used to be called My Computer).
2. Browse to c:\Program Files (x86)\Nova\Print Artist Platinum
3. Right-click on Print Artist.exe and create a shortcut
4. Drag the shortcut to the desktop
5. Double-click on the new shortcut to start the application.
6. Delete the non-working shortcut.
Since I was working with my parents over the phone, some of the file names may be slightly incorrect. However, this should be close enough to get you working.
Jun 29, 2010 | Nova Development Print Artist Version 22...
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
My windows media player won't open up . I double click on the icon on my desktop & nothing happens
that icon is only a shortcut- check and see if its located under "ALL PROGRAMS" and try to click from there otherwise just reinstall it and get the latest version (its free)
Sep 16, 2009 | HP Pavilion Media Center a1330n - AMD...
Cannot find the icon or whatever in order to use the crystal eye
Right click on an open space of your desktop. Select New>Shortcut.
When the Create Shortcut window comes up, click Browse.
Double-click "Computer".
Double-click "Acer (C:)" or your C: drive. It may not be named Acer.
Double-click "Program Files".
Double-click "Acer Crystal Eye webcam".
Click "Acer Crystal Eye webcam" next to the small icon. (NOTE: Do not select the one that just says "Crystal Eye". It is only an icon, not the program.)
Click OK.
Back at the Create Shortcut window, click Next.
Type in whatever name you want to give, or leave the default as is.
Click Finish.
Icon appears on desktop. Double-click the icon to begin the program.
Dec 24, 2008 | Acer Aspire 5520-5908 Notebook
My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Dec 08, 2008 | Computers & Internet
Shut down icon
That is a strange problem.
I will help you to create a shortcut on your desktop for that icon, whenever you need to shutdown your computer, just click that shortcut on the icon.
Right click on the Desktop.
Left click on New > Shortcut.
In the Type the location of the item: textbox enter
%windir%\System32\shutdown.exe -s
The -s parameter is used to shut down the computer.
The following two parameters can be used with -s:
-f Forces running applications to close without warning.
-t xx Set timeout for shutdown to xx seconds.
The following command would shut down instantly.
%windir%\System32\shutdown.exe -s -f -t 00
Click the Next > button.
In the Type a name for this shortcut: textbox enter
Shutdown My Computer (or some other name of your choice)
Click the Finish button.
Whenever you want to shutdown your computer, click the shortcut on your desktop that says ShutDown My Computer, and your comptuer will shut down the usual way, the way it used to shutdown.
Actaviosan
Nov 17, 2007 | Compaq Presario 5000 PC Desktop
Vivitar ViviCam 5385 Digital Camera Logo
21 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
