Question about Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special
I HAVE DC385 NEW. AFTER ONE USE T,THE SWITCH DOES NOT APPEAR TO BE WORKING. ANY IDEAS?
  • 2,176 Answers
I would take it back and get it fied under warranty or replaced, I believe they have at least a 1 year warranty on their products.
Posted on Oct 02, 2009
Why the DC385 does not start /
My guess would be either a failed switch or a failed (motor) brush, unless you've been using it REALLY hard and burned up the motor windings. You'd really have to work it HARD to do that, though.
Aug 04, 2014 | Dewalt Tools (DEWDC385K) 18V Cordless...
DC385 does not run when trigger is pulled with a fresh battery installed.
the armature comuttator can be bad on some collectors and even broken you can hear it if you have a short period for the first time hearing a shrill sound then its also eating brushes and much whistling sound until it become hot control the sliding contacts on the purple and brown wires to the brushes and after that it should only make a buzz sound and has no power give not allways the batteries the blame in most causes like the brands MILWAUKEE and PANASONIC have some brushmotors they have allways the cause of problems EY7441 last a little time of 2 years It is almost a short circuit and then the collectors eating the carbon brushes in a few weeks and make a loud piercing sound, bad for the batteries Milwaukee has the same type of brush engines Johnson when there are people who think the batteries are bad ALLWAYS replace the armature if you hear a shrill sound and the machine become hot believe it in 80 % it is the problem new brushes are eaten again in a few weeks even Makita and Dewalt but not so much as the type of Johnson armatures buying new batteries shall not help much more but you can hear simply the difference and the rpm is much better and again much more powerfull AND MUCH CHEAPER look the difference of the 2 armatures left the older less powerfull armature and on the right the later modificating armature as Panasonic and Milwaukee having with much more power new development but MUCH MORE HEAT DISSIPATION and a very short lasting time if its to much charged then its sounds terrible replace it and your batteries are happy. .4a38f402-6535-4bb2-aaff-bf43754c8cd5.jpg
Oct 17, 2013 | Dewalt Dc385 Reciprocating Saw 18v Tool...
How to grease dewalt dc385
The grease they recomend is part number 286436-00 at a cost of $80.87 for a 1pound can. I'd call the factory at 1-800-433-9258 and see if they offer a smaller tube.
Dec 20, 2012 | Dewalt Dc385 Xrp 18v Cordless Recip Saw...
Saw is smoking
First I would check to two wire leads coming from the switch to the brushes. They will often melt from too much heat. There is a very good chance that the switch is bad too. Here is the parts diagram. The leads I referred to are items 43 and 44.
DeWalt DC385 diagram
Aug 19, 2012 | Dewalt 18v Dc385 Cordless Reciprocating...
18v runs slow/is it the armature
It could be, but it could also be the switch, or a bearing.
Feb 27, 2012 | Dewalt Dc385 Reciprocating Saw 18v Tool...
How do I get a operating manual for a DeWalt DC385 Reciprocation saw
you can download the operators manual from this site
http://servicenet.dewalt.com/Products/Detail?productNumber=DC385B#
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 09, 2011 | Dewalt Dc385 Reciprocating Saw 18v Tool...
I have a Dewalt DC385 Reciprocating saw, when I hold it with the blade down or level the saw will not work but when I have the blade pointed upwards it works fine. I don't think it is the trigger...
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
May 23, 2011 | Dewalt Dc385 Reciprocating Saw 18v Tool...
How do u take off the top of a dc385 cordless sawsal to unscrew the two top screws .. is there any video?
there is no video, but you can download a breakdown for this tool at "dewaltservicenet.com" to see what I am going to explain. first remove the battery, and the pivot shoe. Next pull the gearcase insulator off to expose the gearcase housing and then you will have access to all the screws that have to be removed in order to unscrew the top. The gearcase insulator is sometimes "tight" to remove so you might have to pull hard but it will come off. Let me know if you need more assistance.
Mar 15, 2011 | Dewalt 18v Dc385 Reciprocating Battery...
Can I use a dewalt 18 volt dc9098 battery on the dc385 Saw?
If you have the handle disigned for the lithium battery becareful using the 9096 battery as it moves in the handle a lot and can hit the terminal on the switch wrong and bend it or break it. Also it will get a lot of vibration when running and because it doen't have the support that it needs for a 9096 it wiill likely brak a contact on the switch eventually. the factory does say they work in any tool however.
Feb 14, 2011 | Dewalt 18v Battery Reciprocating Saw Dc385...
I Have a Dewalt DC385 type 2 Reciprocating saw. I push the trigger and it does not work all of a sudden. Could the trigger unit be bad. How can I tell if it is bad, I just dont want to keep replacing...
REMOVE THE BLADE !!!! take the handle apart and lift out the switch. keep track of the lock slide button and how it is installed. unplug the switch wires. carefully touch the wires you just unplugged onto the battery terminals. these wires lead directly to the motor. BEWARE.. if the motor components are good , the saw will run at FULL SPEED. you only need to tap the wires, DO NOT jamb them onto the battery. If the motor runs then most likely the switch is bad. If you know how to use a continuity tester then you can also check the switch. Bad moter likely culprtet is the brushes are crapped out.
Mar 12, 2009 | Dewalt DC385B 18v. Cordless Bare...
Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special Logo
164 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
