Question about Ricoh Office Equipment & Supplies
Where do I find the dipswitch 101-1 on a Richo FT4522 Copier
Where do I find the dipswitch 101-1 to reset the error code E-5 on a Ricoh FT4522 copier?
    President:
  • 1,462 Answers
Here are some answers for your query.
Where is the dipswitch 101-1 ?
Remove the rear cover and in the left side is place where you can find the the main board.
The DIP 101 is located in the main board.
RESET ERROR E-5:
E-codes (E1-E7)are displayed im the copy counter.
Actuallr the error code is not single digit it is two digit, it is either E-52,E-53 or E-54. To display both digits of the E code press the Enter key.
When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.
The following procedure must be performed to clear these service call condition:
Turn ON the main switch.
Turn DIP switch 101-1 ON and OFF.
Turn the main switch OFF and ON.
The meaning for the Error codes:
Code E 52 : Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code E 53 : Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code E 55 : Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective
Please leave me comment,if you need further assistance
RNJ VINODKUMAR
Posted on Oct 02, 2009
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
Richo error code sc 829
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
Apr 05, 2012 | Ricoh Aficio 1035 Copier
Please, I need help with Richo MP7500 with error
SC534 D Fan error 5: duplex exhaust fan
The lock signal remained HIGH for 5 sec.
while the fan that draws air out of the duplex
unit was operating.
• Motor overload due to
obstacle interfering with
operation of the fan
• Fan harness loose,
disconnected, defective
• Fan defective
Jul 28, 2010 | Ricoh Aficio 1013F Copier
We lost the user codes for our ricoh ft4522. how
select user tools, admin , address book you should be able to see the pre programmed user codes. there also should be an option to view or print out the codes
Oct 15, 2009 | Ricoh Aficio 450 Copier
Reset the error code e-5 on a ricoh ft4522
There is no need to use dip switches to reset this error code.Providing that the thermistors are good and they have been installed correctly,here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Aficio 450 Copier
Infotec 5221 displays a E-5 symbol
E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
Aug 14, 2009 | Ricoh Office Equipment & Supplies
RICHO AFICIO 650 SHOW ERROR 890
there soesnt seem to be an error 890 on system but 880 is mlb you could try and go into the service mode by pressing clear yellow button and then press 107 and hold down the stop button.. thsi lets you into the service screen you want copier sp select 5. mode and go to 5-810 sc reset press execute and turn machine off wait and turn back on it coul djust be a signal error for the address book.. good luck A
Jun 12, 2009 | Ricoh Aficio 1018D Copier
Funcional problem code SC542
Hello sir; Follow the steps to reset;
1, press "clear mode", "107", then press and hold "clear/stop" key untill display change.
2, enter 5810, then press "execute" on screen, then press "close".
3, turn power off then back on, it will go back to normal.
Apr 28, 2009 | Ricoh Aficio 1018D Copier
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
103 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
