Question about Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.]
How do I change my black & decker electric drill to go in reverse or forward? As you can see I'm tool challenged. Kathleen
  • 108 Answers
The switch near the trigger that toggles left or right controls that.
Good luck with your project, Kathleen.
Posted on Oct 11, 2009
My black and hammer has no forward, but does operate in reverse
That would be Black and Decker, but what model. Generally forward and reverse are controlled by a switch near the trigger, so you can switch one-handed. You may have to repair or replace that switch, or buy a better drill. While lithium batteries are handy, the plug-in drills last so much longer than batteries, cost less, and often work better.
Jun 01, 2017 | Hammer Drills
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
Black and decker 7120 in reverse
Turn the drill over and push the switch all the way in.
Aug 27, 2013 | Black & Decker Drills
What is the polarity of a 12v Black & Decker Drill?
centre pin on plug socket is usually positive...
think I would **** it and see ....if the replacement charger has a charge light it will probably not light if you have reversed polarity. Had the same problem with VHF portables ...I just cut the wire on new charger and tried both options ..reconnected and a bit of tape...voila.
There is little danger to your drill from getting it wrong as long as a the timing is relatively short.
May 29, 2012 | Black & Decker Drills
How do I change the screw drivers on the black & decker power screw driver?
The black collar should slide forward, allowing for the removal and insertion of bits.
Nov 25, 2010 | Black & Decker Pivot Plus Cordless...
Describe how to remove drill bit and install a
Most cordless drills use keyless chucks these days. Shift the drill into reverse and hold the main body of the chuck. Pull the trigger and the bit should come out. Put it into forward and run it to tighten onto a new bit.
Dec 02, 2009 | Drills
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.] Logo
389 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
