Question about Motorola Mobility V325 Cellular Phone
Im having a promblem dialing the speeddialing ?
I can't remember how to assign a speedial #
Thanks for visiting FixYa!
Speed dial numbers are assigned when you first enter a name and phone number for someone in 'Contacts'. To edit the speed dial number, go to Contacts > (Select the Name of the person you want to change the speeddial # for) > select, Edit > and choose a speed dial number not already assigned. Remember Speeddial #1 is reserved for your voice mail.
If you need more specific directions, please submit another question and include the Make and Model number of your phone.
Apr 02, 2011 | Cell Phones
How to set speed dial on panasonic kx-t7730
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00.
3. Enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial.
4. Press AUTO DIAL / STORE to save your setting.
5. To go to the next speeddial location press SP-PHONE and follow steps 3 and 4 again.
6. Press PROGRAM to exit program mode.
7. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Apr 12, 2010 | Panasonic KX-T7730 Corded Phone
Address storage
Mar 07, 2010 | Panasonic KX-T7730 Corded Phone
CANNOT ENTER NUMBER INTO AUTODIAL.
Feb 03, 2010 | Panasonic KX-T7730 Corded Phone
Speed dailing
Nov 12, 2009 | Panasonic KX-T7730 Corded Phone
How do i program a system speed dial?
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Oct 07, 2009 | Panasonic KX-T7730 Corded Phone
I don't know how to store spped dial numbers. I have 10 numbers to be stored to the Panasonic KX-T7730. Unfortunately the described way as per the users' manunal didn't work. Please help
If you are using the KX-T7730 phone on a Panasonic 308/824 system. From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate / vote this answer if it was helpful.
Thank you.
Oct 05, 2009 | Panasonic KX-T7730 Corded Phone
I have a panasonic KX-T7300 and want to assign new speed dial numbers. I have the manual but it doesn't show how to do this please help.
Thank you.
Oct 01, 2009 | Panasonic KX-T7730 Corded Phone
I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
Thank you.
Sep 14, 2009 | Panasonic KX-T7730 Corded Phone
Program and use speed dial numbers
speed dial must set at port ' 00 ' or 000
to check, use display phone, press #402 or #401
speed dial code are from 60 to 99
to set press speed dial , redial , speed dial code eg. 60, press 9 follow by destination number asn redial to confirm
to use speed dial to call press speed dial short key follow by speed dial code or *60
May 26, 2009 | Toshiba Lands Phones
Motorola Mobility V325 Cellular Phone Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
