Question about Moen TL3450/3600/3371 Kingsley Handle Tub and Shower Faucet....
No hot h20 pressure, cold h20 has lots of pressure, when turned to 3 o'clock pressure drops off. moen 3371 valve.
  • 127 Answers
Sounds like the balancing spool is froze up....you may be able to take it apart and free it up...calcium is usually the culprit. If you can not...then you will need to replace it.
Posted on Oct 18, 2009
Installed a new shower and have only cold water hooked up but only getting a trickle of water through it.
Lots of shower valves have pressure balancing cartridges nowadays in order to get full flow out of hot or cold you have to have both the hot and cold hooked up to give even pressure on both sides of the cartridge that should fix your problem and give you a full flow
Mar 27, 2016 | Moen Home
I have moen #3330 shower unit.All is installed but cannot get water to flow. What do I need to do???
First I would check that there is no debris stuck in the valve. In most cases if this is a pressure balanced valve if either the cold or hot water side does not have pressure the valve will not function. When installing the valve was it soldered in? If so was the valve cartridge removed when soldering? Was the valve body flushed after installation before the valve body installed if removed during installation? That model has plastic valve cartridges which are very sensitive to heat and must be removed before soldering.Also the valve body has intergal shut offs make sure that they are turned to the on position for both hot and cold. As I said above being that this is a pressure balanced valve water pressure must be available from both hot and cold. If either hot or cold has less pressure then the other the valve will balance the pressure to be equal, this is to prevent scalding.
Sep 29, 2014 | Moen 3330 Moentrol 3-Function Built In...
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
When i move shower valve to hot, the water pressure drops. There is more cold water than hot. I have changed my moen valve before and this still happens. Good water any where else in the house including...
probably have a kink on how water line feeding valve..if possible to cut drywall bhind tub valve and inspect pipe at bottom plate...moen faucets are equipped w/ anti scald device, pressure balanced (newer models) and this could cause cold water to overwhelm hot water...
Nov 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
I just installed a Moen shower valve Model 82910cbn. The cold water supply is on. The shower works when the cold and hot water is going to the valve, but when I turn off the cold water supply going into...
This is taken from the Moen manual. You can download it here:
http://www.moen.com/shared/pdf/instruction_sheets/ins162e.pdf
Balance Spool Maintenance
The precise and instantaneous pressure control illustrated has been
achieved through the balancing spool, which has been manufactured to
exacting tolerances.
During construction or valve installation, foreign material such as solder
flux, pipe cuttings sand, dirt or wood is unavoidably introduced into the
water system. Occasionally, however, rare, these foreign materials can
cause the balancing spool to become stuck temporarily between the
rough-in and trim-out operations. If this happens, it will be apparent at
the trim-out test, in that the valve will deliver only a small trickle of water
or it will deliver only hot or cold water. If this occurs, proceed as follows:
1. Make sure that both the hot and cold water service lines are ON. Also,
make sure that both screwdriver stop-check valves are open. The valve
WILL NOT OPERATE unless both supplies are ON.
2. If the valve still does not function properly, turn off both the hot and
cold supplies and remove the balancing spool, using a wide blade
screwdriver. The inner piston of the balancing spool should shake
back and forth freely. If this is not the case, jar the spool on either
end to remove the foreign material and free the spool. When the
spool is free, replace it; turn ON both water supplies and the valve
will function properly. If you are unable to free the inner piston,
replace the entire spool.
Oct 16, 2010 | Moen 3175 Legend One Handle Shower Faucet...
HOT AND COLD REVERSED MOEN & ONE HANDLE TUB
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Aug 26, 2010 | Moen & One Handle Tub & Shower Faucet
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Not alot of hot water?
1st Check the temperature restricting coller behind the cover under the handle. It is used to restrict the flow of hot water to stop you from being scaulded.
2nd Those set screws will control the flow. Check to ensure both sides are open the same amount of turns. If the water pressure is good turn in the cold side.
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen TL3450/3600/3371 Kingsley Handle Tub and Shower Faucet.... Logo
172 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
