Question about KitchenAid 24 in. KUDS02SRSS Stainless Steel Built-in Dishwasher
Kitchenaid dishwasher KUDS02SRSS1 has normal light blinking
Kitchenaid KUDS02SRSS1 dishwasher has normal light blinking and display has two lines "--". What should I do?
  • 58 Answers
SOURCE: Kitchenaid Dishwasher KUDIO1DL Dead?
could have a bad start button
Posted on Oct 31, 2007
  • 3 Answers
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Posted on Apr 27, 2009
  • 56 Answers
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
Posted on May 31, 2009
  • 1015 Answers
SOURCE: my KitchenAid dishwasher will not run. Start light is blinking
Make sure the controls are not locked. Some units have the ability to lock the controls so that kids cannot turn on the dishwaher. You can also try unpugging the power to the unit from under the sink for about 10 minutes and then plug it back in. This may reset the control board if it has a fault and stopped from error code.
Posted on Sep 26, 2009
SOURCE: **My dishwasher normal light keeps blinking**
I have the same problem. I have tried turning off the breaker and the door seems to be locking, but still won't work. Any other suggestions?
Posted on Dec 13, 2009
Kitchenaid dishwasher kuds30ivwh3 start light blinking. Dishwasher won't start.
Press these keys :
Heated Dry----> Normal-----> Heated Dry-----> Normal
All the l.e.d.s should lite up and then, if you push start, it will go from function to function. push the button 8 or 9 times, then
Reset the power to the unit via the circuit break, then run a normal wash cycle and see if it completes...
Nov 20, 2016 | KitchenAid Dishwashers
KUDP01ILBL6
Technical sheet say you have a stuck key on the keypad
Feb 04, 2014 | KitchenAid Dishwashers
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
Control panel cancel light blinking as well as normal and light china light cannot cancel or start dishwasher
where do i connect the upper rack water conduit tube for the kitchenaid dishwasher
Aug 16, 2009 | KitchenAid Dishwashers
My normal cycle and cancel button lights are blinking on my kitchenaid dishwasher. Model # KUDP02CR8S2 Any suggestions?
Apr 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
KitchenAid 24 in. KUDS02SRSS Stainless Steel Built-in Dishwasher Logo
241 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
