Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Ice machine cubes not big enough do i need to open up ice thickness control
  • Anonymous Oct 11, 2008
    good start, which way is ice thicker, up or down?
  • Robert Frank Sr. Apr 18, 2013
    down
    Director Badge:
    Uploaded 100 video answers.
  • Hoshizaki Master
  • 488 Answers
3 beeps. hoshizaki replacing txv
Posted on Oct 24, 2015
    New Friend:
  • 39 Answers
It is exceeding the time to run a freeze cycle and shutting
off on a programmed saftey limit. There are several different
problems that can cause it to do this from a low charge , txv starving, or inefficient compressor or just a dirty water system. you may need a qualified
technician to check it out.
Posted on Apr 18, 2013
    Problem Solver:
  • 27 Answers
Sir ,
I'm read in your problem,pls cheaked the compressor amps, compressor working not properly,
Posted on May 27, 2008
I have a Hoshizaki ice maker machine model # 350
It is pluged in and running it makes ice within 1.5 hour and drop the ice after which it does not make anymore ice .
It has this beeping sound in the control electronic circuit
can you tell me what is the cause for it not making ice consistently and what to look for.
Posted on Mar 27, 2008
    Sergeant:
  • 288 Answers
Is this a hoshiziki or a Scotsman? If you pull the front cover off the machine, is the ice being made by a large flat grid, resembling a big waffle? If so there is a contact control that has a probe touching the flat metal panel, this has an adjustment screw on it. If you have a larger type of ice maker that has a couple of vertical rows with tanks on the top draining water down to the bottom, then remove the front panel and to the left bottom, there will be a tubular looking device that has a hose on the bottom and top. there will be 2 screws, loosen them and slide the round thing up or down to adjust the size of the cubes.
Posted on Dec 23, 2007
Why would a hoshikia 450 mab jump from freeze cycle to harvest cycle without giving iot enough time to makle aload. would it be the cube sizer adjustment or a bad borard?
clean and dry the sensor and restart the machine. Adjust the thickness until the cubes make a plate but break apart when they fall in the storage bin
Jun 01, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Ice machine not making enough ice
Need some more details. Size of cubes too small? Batches of ice take too long to make? (Over 45 minutes?)
May 16, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Ice thickness control
The ice thicknes control is located on the bottom left. it has a wire going
to it and ha a black rubber bottom. depending on the position it is secured.
will determine the ice thickness. loosen the two screws and push it higher
for smaller cubes and lower for bigger. If you are having problems with it.
There is the possibility it is dirty and sticking.
Jan 14, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki M# DCM-270BAH-OS runs for days then freezes up evap coil and stops water inlet to evap.
There is a thermostat probe sat on the front of the evaporator to tell the control board when to harvest. Check it is tight in it's holder. Check the condenser is absolutely clean and filters clear. You can adjust the thickness of the cube. set it on the thinnest setting and see if it harvests before freezing solid.
Jun 15, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I Have A KM-900MRH Ice Machine Hoshizaky i, recently changed the water pump, and now sims to be that ice is really thin, and is not making enough.
adjust the float (White plastic with black rubber bottom) item next to the water pump. It needs to be all the way down. Loosen the 2 screws and slide it down all the way. This is what controls the size of the ice cube. Other possibility is that there is water leaking our of the sump causing and early harvest cycle to start. Look for both.
Sep 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Km500mae never shuts off
this is easy to fix first you need some food grade hose next put this hose in the bottom of your ice bin then run you water through this hose to the machine fit as much hose as you can in the bin floor and start the machine at night and the other thing you may wish to do is get a remote condenser
Apr 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Ice Machine FIM600 Ice is making too big
remove front cover to view control panel. there is a cube size adjustment there. use a small screwdriver and turn it counterclockwise to make the cubes smaller
Jan 07, 2009 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Please Heal
starving for water. clean or replace water filter or adjust water float assembly that determines how big cubes are. probably not getting abundant water during timed fill sequence. no water equals little ice.
Sep 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
541 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
