I have a hp color lasorjet 3800N printer and am getting the following error message 10.92.03 cartridges not engaged. OPening and closing the door does not correct the problem. How do I fix?
    President:
  • 2,306 Answers
Any of the 10 series errors are saying the cartridges are not correct or not installed properly. The first place to start is remove each cartridge wipe the contacts and make sure all are installed fully. After that, if you still have the error you might have gotten a defective cartridge if one was replaced recently.
Posted on Oct 02, 2009
Cartridges not engaged error 10 92 03 hp 3800n
Sounds like one or more of the cartridge lock levers or slide levers may be broken. If this printer is very old, you may want to consider replacing it. See...
http://printertechsforum.com/forum/showthread.php?3861-HP-LaserJet-3800n-10-92-03-cartridges-not-engaged-error
May 19, 2014 | Canon Computers & Internet
Door closes with no cartridges but will not with cartridges. looks fine, worked fine before putting in new cartridges for the 1st time. hp color lasorjet 3600n
Did you make sure the cartridges clicks in place? There are while plastic locks on each cartridge and hopefully they are not broken. Not expensive to purchase but major teardown to replace.
Oct 23, 2013 | HP LaserJet 3600n Printer
Error message 10.92.03 in hp 3800n
Yellow cartridge isn't seated correctly. After reseating it and it still gets the error, try swapping the yellow and black cartridge. If the error changes to 10.92.00 then the yellow is bad. if the error stays the same...something is broken, probably the "cartridge lock" for the yellow.
Dec 19, 2009 | HP LaserJet 3800n Printer
My HP 3920 is showing error of "The following print cartridge is not intended for use in this printer Tri-color" and Status is : paper jam. Any body can help me how can i fix it?Thanks
If you know you have the right cartridge, and it is inserted correctly, you might try opening and closing the paper jam door in the back of the printer. Sometimes the printer gets "confused" as to what the real problem.Or, at least my HP printer does.
Dec 13, 2009 | HP DeskJet F380 All-In-One Printer
Hp color laserjet 3550 - error message "cartridges not engaged"
here are the codes for the error you are getting
10.92.00 Black toner
10.92.01 Cyan
10.92.02 Magenta
10.92.03 Yellow
The fix is either the toner lock is broken. Contacts on the left side of printer are damaged.
There is a complete proceedure for replacing the the toner locks which comes in a kit you can order from precisionroller.com. this takes about an hour.
If the contacts are damaged you will have to replace the whole plastic part on the left side behind all of the electronics. It takes about an hour
Jun 14, 2009 | HP Color LaserJet 3500 Printer
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP Officejet 5610 All-in-One--Cartridge Error
    If a reset hasn't cured this problem you probably need to disassemble the printer and clean the service station and the system board. This normally clear all carriage and cartridge errors, but these machines are quite awkward to take apart.
    May 14, 2008 | HP Officejet 5610 All-In-One InkJet...
    HP 3500 color printer
    If you can see what is stopping the door from closing, and it appears to be on the right side of the printer near the top where the cartridge engaging pins are, and you remove all the cartridges and transfer belt and the door closes well, you may want to try this: There is a small silver screw at the top of the right corner of the case. When our front door would not close properly with the cartridges and transfer belt assembly installed, I took off the right side cover and took out that top corner screw. Then I slid the long white engaging rack that is on the lower right side of the printer toward the front door, which retracted those cartridge pins that are triangularly-shaped on their ends. Once the door would close properly with the cartridges and the transfer belt installed,and the pins engaged properly to open the cartridges as the door closed, I put the top corner screw back in and the side cover back on. I hope that helps you.
    Sep 17, 2007 | HP Color LaserJet 3500 Printer
    476 people viewed this question
    jasbo
    jasbo
