Question about HP Computers & Internet
Server``s temperature is outside of the normal operating range.
I am always getting this alert from one of my servers HP ProLiant DL380 G6
yet there is no indication when at the machine that this is happening at all - I have been trying to find a way to correct this or adjust HP Sims to have a higher thermal threshold as I am getting these msg's every few minutes all day every day
Event description: The temperature status has been set to degraded in the specified chassis and location. The server``s temperature is outside of the normal operating range. The server will be shutdown if the cpqHeThermalDegradedAction variable is set to shutdown(3).
Chassis Number: continue
Bay Number: 0
Detailed Status: system
If anyone knows of a patch or firmware issue that would resolve this it would be much appreciated
  • HP Master
  • 20,706 Answers
It's overheating
first prove it's not .
if not, then fix the sensor.
its there for a very important reason, do not hack it.
or ask for help at HP.com
click support.
is this hard, to do that?
Posted on Mar 18, 2017
saqeb
  • 47 Answers
SOURCE: 02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Posted on Jan 28, 2009
  • 101 Answers
SOURCE: server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Posted on Mar 02, 2009
nicarta
  • 506 Answers
SOURCE: POST errors forcing server to crash
Its best you log a case with HP support. If your system is still under warranty or if you bought support along with the system, they will fix the problem for you.
Posted on May 29, 2010
info2u
  • 596 Answers
SOURCE: how do i boot a compaq proliant dl380 with a usb
Make sure you have turned on the USB Boot in the BIOS of the os. Once this is done, select the order you would like for the server to locate boot files. (Hard Drive, USB, CD/DVD, etc.) Once complete, insert the USB and reboot the server.
Good Luck
C2S
Posted on Jul 07, 2010
SOURCE: HP Proliant Server DL380 G4 wont boot no display
Clear NVRAM.
Posted on Nov 28, 2011
Dl380 g6 server not boot after power cut
Check the back for a bad power supply. You should be using dual power with dual supply. It should have indicator light on somewhere. Connect to another source if no LED is on.
Oct 20, 2012 | HP ProLiant DL380 G6 Server
Configure static ip on a HP 380 G6
Here is an awesome image tutorial on how to do it
http://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
Oct 15, 2012 | HP ProLiant DL380 G6 Server
Hp dl380 g6 server shutdown unexpectedly
Check event viewer for Window. Insight Manager (if installed) for HP related problems. Type server name or IP on browser. examples: 192.168.2.1:2301. Localhost:2301. 127.0.0.1 again local.
May 23, 2012 | HP ProLiant DL380 G6 Server
I can't boot my hp prolinat server 380g6
I would recommend resetting the jumper switch and the BIOS then retry your install.
Good Luck
C2Solutions
Nov 15, 2011 | HP ProLiant DL380 G6 Server
Hp pavilion dl380 g6 unaccepted restart
Clearly explain about your problem.
It would be HP Proliant DL380 G6 server
Oct 06, 2011 | HP Compaq ProLiant DL380 G4 Server
How can i boot my hp dl380 g6 server in safe mode ? the F8 key didnt help me to boot in safe mode
Different system use different F keys to get to safe mode, If F8 is not it, try F10.
Good Luck
C2Solutions
Feb 14, 2011 | HP ProLiant DL380 G6 Server
Proliant DL380 G4 server occasionally rebootes.
Try to update the firmwares. Maybe the threeshould of the fans are incorrect. A new firmware can correct this problem.
Let me know if this post helps
Nov 08, 2007 | HP Compaq ProLiant DL380 G4 Server
Computers & Internet Logo
531 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
