Question about Hayward Sp2805x7 Max-Flo 3/4 Hp Swimming Pool Pump
How do i remove the impeller from a self priming max-flow pump by hayward
    President:
  • Hayward Master
  • 1,378 Answers
Lock the shaft at the back of the motor and spin the impeller off counter-clockwise.
Posted on Oct 02, 2009
Hayward super pump won't prime
Priming issues are almost always due to a bad gasket or loose fitting.
  1. Remove the leaf trap lid. Examine the gasket for debris, cuts or folds that might prevent a tight seal.
  2. Remove and examine the winter plugs for proper seal.
  3. Remove, re-tape or putty the threaded fitting directly in from of the pump.
  4. Check all unions, fittings and connections from the skimmer and main drain to the pump.
  5. On rare occasions the impeller may be impacted with debris preventing water flow. Remove the four screws holding the motor to the wet end exposing the impeller and examine it. Hayward impellers are also know to break at the shaft. This will sound like the pump is operating but never pumping water.
  6. If everything looks normal, try pouring water over the entire wet end while priming. This will sometimes allow water to fill a void you missed. The pump will probably loose prime again until the issue is corrected.
Aug 17, 2014 | Pool & Spa
Hayward 1hp super pump-self priming -rebuilt won't run
something is binding take apart and try again
Jul 30, 2013 | Hayward Pool & Spa
Hayward pool pumps
The impeller on this Hayward pump unthreads counter clockwise.
Take a big flat head screw driver and put it on the center shaft on the back of the motor to hold the shaft solid while you unthread the impeller.
Rod
US Parts Center
May 08, 2013 | Pool & Spa
My pump and filter has been working perfectly, even thruout rain storms. Today, It is raining heavily in central NJ and The motor is rumming, but no flow from the return. As if a connection o is broken...
Try to prime the pump!!! Also, if you have a system that used diatomaceous earth, may need to clean and add??? Last resort after checking for flow problems, filter and prime is to open the pump and check the impeller.. Good luck...
Aug 14, 2011 | Hayward 1.5hp Power Matrix Above Ground...
Pump was running very loud for some time now it comes on and no water is pumping through the system.
Friend had similar problem... Clean filter, added earth, primed pump and sound went away and had great flow... If not, possible impeller problem..
Jul 14, 2011 | Hayward SP3015X20AZ 2 HP SUPER PUMP II ...
Frozen impeller. What is the proper repair or does the impeller need to be replaced
NOT ALL THE TIME THERE IS TWO TYPES, ONE HAS BRASS THREADS THE OTHER IS ALL PLASTIC, WHEN YOU UN-SCREW (LEFT) HOLD SHAFT AT BACK OF MOTOR WITH 7/16 WRENCH, PLASTIC IMPELLERS ON THE SMALL MOTORS CAN BE REUSED . BUT ON A 1.5 AND BIGGER.IT'S A MUST TO REPLACE IT WITH THE BRASS THREADED IMPELLER. I THINK YOU WILL FIND THAT THE MOTORS ROTOR IS LOCKED UP AND WILL NEED TO BE REBUILT, YOU MAY BE ABLE TO ROCK THE IMPELLER, AND WITH SOME LUCK FREE THE MOTOR.. GOOD LUCK, AND PRIME THAT PUMP AFTER ANY PUMP REPAIR !!.. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA..
Jun 03, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Ihave a hayward 1hp inground pool pump and can not get the impellar off
you will need to hold the motor shaft at the back of the motor with either a 7/16 open end wrench, or either armature tool. You can then use a closed face impeller wrench to remove it. Make sure if there is a screw in the center of the impeller to remove it by turning clockwise.
Sep 06, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Pump wont run
does it turn freely if not check pump impeller for debris or damage repair or replace if necessary--if good- check motor bearings if not turning may need to be lubed or motor replaced check amp draw if spiked or nothing than possible open winding and may need replacement
Apr 08, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward Sp2805x7 Max-Flo 3/4 Hp Swimming Pool Pump Logo
158 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
