Question about Sony Cyber-Shot DSC-T1 Digital Camera
In auto mode greens look brown.same thing happens in most program modes this shows up on camera lcd also when viewed on computer
Hi, I have a Canon IXUS 95IS camera.. For some reason, when I attempt to take a photo, the LCD screen isn't displaying what is actually in view? In movie mode it comes up on the screen but when i flick it...
Ah yes! you have pressed the display button. Turn the camera on and you see the icons in the display, look for the Disp button and press it, the display will cycle through its modes icons, black, image and icons.
Jan 22, 2010 | Cameras
The LCD monitor doesn't show the image that the viewfinder shows. The screen is black.
To do this you need to activate Live view mode (Only works in non-Auto modes P to A-Dep). Press the SET button well in one of these modes, use the Button marked with a star to Focus.
Also you made need to Turn on Live View in the settings Menu.
Oct 30, 2009 | Canon EOS Rebel XSi Digital Camera
My monitor shows "auto detection mode
make sure the video card is securly placed in the pci-e slot
Aug 19, 2009 | Dell E228WFP LCD Monitor
Can not see my subject through the lcd screen
I believe that the "LIVE VIEW" shooting can only be done in Auto mode. Once in Auto mode, try pressing the SET button located to the right of the LCD screen. Once depressed, you should hear a quick click noise and see what the lens is seeing on the LCD screen. Click on it again and it should revert back to "viewfinder" mode.
I Can Fix It
Jul 10, 2009 | Canon EOS Rebel XSi Digital Camera
My sony DSC-H1's LCD is not showing anything...but I can operate the camera with its view finder... Do you have any idea why it happens? and is there any master reset option for this camera?
I have a similar SONY camera. Turn the camera on and to the right of the viewfinder (or perhaps in a different location on your model) there will be a small button that reads, "FINDER/LCD". Press that button once to see if your view switches back from viewfinder mode to LCD display mode.
Jun 23, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Screen shuts off. Power lite blinks. Aquos 42"
Hope you have the correct resolution selected:
HD View Modes: When viewing an HD program you can select the following 4 viewing modes.
  • Stretch: suitable for viewing 1.78:1 DVDs. When viewing 1.85:1 DVDs, this mode will show thin black bands at top and bottom of the screen.
  • Dot by Dot (1080i/p only): detects the resolution of the signal and displays an image with the same number of pixels on the screen. When a 720p signal is being input, the image will be delivered in full screen.
  • Smart Stretch: suitable for stretching 4:3 programs to fill the screen.
  • Zoom: suitable for viewing wide-screen 2.35:1 aspect-ratio programs in full screen.
PC View Modes: You can connect the TV to your PC through the HDMI inputs to use the TV as a monitor. The following view modes are available in PC mode.
  • 4:3 Input Signal: You can select between Normal, Zoom, Stretch, or Dot by Dot.
  • 16:9 Input Signal: You can select between Stretch or Dot by Dot.
Also verify if you have set auto timer to 30 mins or so thats why the TV shuts down after a particular time.
Thanks
May 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
LCD not working
There's a good possibilty that your mode switch is broken. Same thing happened to my Z6. I was able to source replacement switches, and can replace them.
Jan 14, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Video Problems
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to normal_mode.gif.
mode_dial.gif 3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Jun 10, 2007 | Canon PowerShot A400 Digital Camera
Manual Shutter Priority Settings
Try the PROGRAM MODE-SPORTS setting. this will keep the shutter speed reletively high unless there is little light. Or use APERTURE PRIORITY MODE with an f2.0 to f2.8 to keep shutter speed high. If pictures were blurry when it went to AUTO then the light had to be low for the camera to select a low shutter speed. If using flash use forced or auto flash not slow sync. Also set ISO to 400 which is >>>. If inside use a larger external flash as the one on-camera is only good for about 10ft. if more than 10ft. away set focus to manual infinity so you don't have to wait for the camera to focus. Hope this helps.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
18 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
