Question about Garmin nuvi 350 GPS Receiver
I am actually removing my Garmin GPS from a 2008 Nissan Versa. I cannot find where the other end of the wire is at where the wire is connected to? It's not wire direct to battery, so I am guessing it must be the ignition?? Looked everywhere, and cannot see the wire...
  • Garmin Master
  • 638 Answers
Contact Nissan, we have no way of knowing how the manufacturer wired the unit into the vehicle.
Posted on Jan 29, 2010
Removing tensioner assembly
images for 2008 Nissan Versa Removing tensioner
    how do you remove tension off surpentine belt tensioner - Nissan Forum
    www.nissanforums.com/.../151350-how-do-you-remove-tension-off.htm...
    Feb 20, 2009 - 4 posts - ‎2 authors
    2008+ Nissan Rogue ... QR25 2.5L Engine Engine Discussion: 2002+ Sentra SE-R and SpecV ... how do you remove tension off surpentine belt tensioner ... changed these before, but which way do you turn the tensioner, how ... Replacing the Water Pump on a '04-'08 Maxima *DIY*
    1 post
    Aug 31, 2011
    Belt noise: replace idler pulley? - GA16DE
    Sep 16, 2008
    Step by step instructions -Upper Timing Chain Tensioner
    Dec 8, 2007
    Idler Pulley Bearing Replacement Info
    May 16, 2003
    More results from www.nissanforums.com
    Nissan Versa Tensioner Pulley Issue (1/1) - EricTheCarGuy ...
    www.ericthecarguy.com/.../50669-nissan-versa-tensioner-pulley-issue
    Nissan Versa Tensioner Pulley Issue 1 year 7 months ago #94552 ... for a 50 Torx to be used to remove the entire tensioner pulley assembly but all of my 50Trx
    How to Replace serpentine belt 2008 Nissan Altima ...
    ? 11:29
    https://www.youtube.com/watch?v=5NchA85pnAE
    Jul 2, 2014 - Uploaded by nivekoch
    How to Replace serpentine belt 2008 Nissan Altima In this video i'll be going ... 2005 Nissan Altima 2.5L serpentine belt tensionerreplacement ...
Dec 16, 2015 | 2008 Nissan Versa
2008 nissan versa right headligh low and high filement on on low and nothing on high
check the wireing that the bulb goes into probley theres a faulty or loosened 1 : )
Jan 14, 2013 | 2008 Nissan Versa
How do iI change 2008 nissan versa sprkplug
You must remove intake manifold ( make sure you replace gaskets) remove coils and remove spark plugs denso iridium tipped plugs are the recommended plugs to go with
Aug 04, 2011 | 2008 Nissan Versa
How do I change the spark plugs on my 2008 Nissan Versa?
No answer here. Looks like you have to remove the intake manifold (5- 10mm bolts in front, on the rear at the throttle body, it looks like connect from air intake snorkel, remove snorkel and take out the bolt on the other side to get to the plugs. This POS site tells you nothing useful.
Feb 14, 2011 | 2008 Nissan Versa
Nissan versa heater fan removal ,mice nest in heater box, need to clean. how do i remove the box/or fan
2008 nissan versa mice nest in heater fan box. how do i remove heater fan blower?
Jul 14, 2010 | 2008 Nissan Versa
My garmin gtm21 lead has broken
Read this post for the pin-outs.
http://www.gpsdiscussion.com/garmin-gps/7316-gtm21-pin-outs.html
Feb 08, 2010 | Garmin StreetPilot c510 Deluxe GPS...
MY STREET PILOT C330 DOES NOT RECEIVE SIGNAL IN MY 2008 TOYOTA HI
Most likely, the there is something in the construction by shape or dimensions of the vehicle that is attenuating the signal strength. Microwave frequencies such as from satellites can be critical.
If your GPS has an external antenna connection, you can go to a Garmin dealer and get an external antenna kit. This should increase the reception strength.
Just for your interest, the newer models of GPS have improved design of their front end, thus giving better reception. I found this right away when I bought a new GPS.
Jerry G.
Dec 02, 2008 | Garmin StreetPilot C330 GPS Receiver
My map on my garmine 60csx doesnt line up with the actual locations
The most common cause of consistent offset is DATUM selection. The DATUM was likely set to WGS84 at the time of recording then viewed later in NAD27, or vice versa.
Geocaching.com uses WGS84. The USGS generally uses NAD27
Also see this Garmin page. The DATUM is set under Settings | System if I recall correctly.
Oct 22, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Wont turn on
Question: Why won't my unit charge while plugged into my vehicle?
From the Garmin site: --> Answer: If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece. fileservlet?date=1&kb={6b85cfa0-194d-11dc-44cd-000000000000}&id={6e53bea0-6874-11dd-436f-000000000000}&ext=jpg
  2. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  3. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
fileservlet?date=1&kb={6b85cfa0-194d-11dc-44cd-000000000000}&id={6e476290-6874-11dd-436f-000000000000}&ext=jpg //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 08/12/2008
Sep 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
