Question about Lexmark X3650 Printer
We keep getting a paper jam problem, How do you
We keep getting a paper jam problem, How do you remove jammed paper
  • 395 Answers
First and foremost make sure the paper you are using is dry, if the paper you are using is damp you will continue to have this problem. Removing jam papers involves you first removing the cartridge then you'll find the paper compartment.
Good Luck.
Posted on Oct 02, 2009
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
I face a paper jam a lot, what is the right steps to release it? I keep getting a paper jam message. I have opened up the case and inspected; removed the cartridge and inspected; no paper/paper jam found....
Turn printer upside down (yes), and check that there is no small paper or foreign objects inside the printer, ensure all door are closed, unplug printer power cable for 2 minutes to reset.
Jul 29, 2008 | Konica Minolta PagePro 1350W Laser Printer
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Epson 837 printer error
OK, often when removing a paper jam this can happen:
1) - when pulling the jammed paper out you can leave behind a small piece or loosen up another small piece from a previous jam. This piece can then become the 'new' jam by clogging the jam sensor or switch. Use a small flashlight to look done the previous jammed area to see if this is the case.
2) - when pulling the jammed paper out you can 'mis align' or damage the jam sensor (or switch) so that it always registers a jam. this fix may require a technician or repair shop to fix.
Feb 04, 2014 | Epson Artisan 800 All-In-One InkJet...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Brother DCP-145C. Paper jam removed. Light keeps flashing. How can I switch it off? HELP!
There will still be some scrap of paper in the machine. Get a torch and get in there. It's the only way, unless you call tech guy
Apr 28, 2009 | Office Equipment & Supplies
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Lexmark X3650 Printer Logo
326 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
