Question about JVC AV-32F476 32 in. Television
Television repairs cable "plug" wss pulled out. Approx. how much will this cost to repair
  • guinness1222 Dec 21, 2007
Can you repair it yourself? Do you have any solder?
Posted on Oct 01, 2008
Approx cost to repair 50 inch Panasonic plasma Blinking 8 red light code
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Nobody can predict about the repair charge, as it will depend on the cost of damaged component/s + Service charges. OK?
Dec 10, 2014 | Panasonic Televison & Video
I pulled out the cable plug from the tv unit where the cable wire connects. Can this be repaired?
The threaded core that was pulled off the main board might be repairable. It just depends on what the tuner on the main board looks like now. However, It may be too bad to repair.
Keep in mind, if a shop does solder the core back on… it will not be as strong and it could easily break off again. Also, the repair shop may charge you almost as much as a new board for this type of repair.
The best way to repair your TV is to get a new main board.
I can get you the part number if you need it. Good Luck.
May 18, 2010 | iLO LCT32HA36 Television
Picture pulls down at top
Ur Convergence ICS is the cause is shorted about to dies.U know how to solders?Tries Tv repair World.com,Tvrepairkits.com to buy the convergece kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 04, 2010 | Mitsubishi VS-50605 50" Rear Projection...
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have two thick black lines running vertically on the plasma
Thanks
Sep 08, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
What is the approx cost to repaire the freeze plug
If you tap it in yourself, which sould be simple depending on the location, the plug will cost you a couple of dollars. You can also put in a rubber expandable plug that you can tighten with a wrench. Your local auto parts store will be able to help you decide which one would be best for you but the actual plug is very inexpensive.
Apr 16, 2009 | 1999 Ford Taurus
Avtex 15 in tv/dvd freeview /dadio combined. It will not power up. What would be approx. cost to repair it please
usually $60.00 to $150 depending on the problem. You can find a local tecnician by using our online repair service search engine.
thanks,
Jun 28, 2008 | Televison & Video
While moving my set the cable conection was pulled out, is it a fixable task,or is it toast?
As long as the PC board inside teh tuner was not broken, the "F" connector can be replaced. This is a relatively simple repair for a service shop. The part costs about $2-$5. Add the local labor charge to that for the total repair cost.
Dan
Mar 17, 2008 | Televison & Video
JVC AV-32F476 32 in. Television Logo
61 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
