Question about HP LaserJet P3005n Printer
It is a networked printer but it will not print I can turn it off and turn it back on and it sound like it will work but no. nothing appears in the little screeen. none of the buttons make anything happen.
  • 99 Answers
When in ready state try pressing the big green button for 5 seconds to print a test page if it does then check if there is an I.P Address on the test page
Posted on Oct 03, 2009
I am getting an error of: 49.4Co2 on my HP color laserJet 5550hdn. Have tied turning it off; unplugging butno luck. the error message continues to appear
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application.
If the job prints, go back to the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all
cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer.
Aug 29, 2011 | HP Color LaserJet 5550hdn Printer
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My Dell 5130cdn says it is ready to print and is turned on, but when it comes to printing, the computer tells me that it is not turned on at all. We've turned it off completely and then turned it back on...
Sounds like you have no communication between the print and PC on the network, check the network cables, both devices are on the same network, ping the printer, assuming you can access the internet.
Feb 07, 2011 | Dell 5130cdn Printer
Xerox 8500 not printing
It sounds like you need to check your addressing. Sounds to me like your IP address reset back to default.
You need to go into the network settings and check your IP address and make sure it is set to manual and not auto.
I believe your printer did a reset and your address is wrong.
Jun 27, 2008 | Xerox Phaser 8500/DN Printer
Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
May 30, 2008 | Brother HL-5240 Laser Printer
Nothing printing
I work mostly with Datamax's.
If you push the feed button does it feed and stop where it's supposed to?
Turn it off, unplugg the network ( about 5' ) turn it back on, plugg in  the network ( clear all jobs from the queu, which sometimes may have jobs in there that are frozen), do an internal test print and try to print a job.
Also try to re-calibrate the media.
Oct 01, 2007 | Zebra S4M Thermal Label Printer
Wireless printer
it sounds as if the printer may not be set as the default printer, so check in the installed printers and check and also check that the printer you are sending the print to is the setup one and not a pdf or microsoft office document printer, this is found on the drop down box when the print option appears. i am also assuming that the printer has worked before from vista to an xp machine as sometimes xp needs a small update to be used with a vista pc on the network
Jun 12, 2007 | Linksys (WKPC54GCU) 802.11g/b Wireless...
HP LaserJet P3005n Printer Logo
62 people viewed this question
Ben Johnson
