Question about Roper RES7646KQ Electric Dryer
Kenmore heavy duty plus
My dryer has power and seems to be working, but the drum inside wont spin the clothes. Is it worth repairing
  • 833 Answers
Sure. The likely problem is a broken belt. Do you hear the motor? If not, it could be the motor. Pull the back off the unit...with the power off and have a look.
Posted on Dec 21, 2007
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Dryer leaving black marks on clothes
Depends on age..its the bearings that gone, normally a felt bearing seal the drum and wears after about 4 cost about.£ you decide. please leave feedback
Apr 07, 2010 | Dryers
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore heavy duty clothes dryer will not heat
Feb 25, 2009 | Kenmore Dryers
Kenmore heavy duty
I can only assume by rollers you mean bearings were replaced. Unless your dad measured both the ID Fit of the bearing and the OD fit [ inside diameter and outside diameter of the shaft and housings] new bearings could be on the small side of their tolerance, [new bearings are made to be within a certain amount of "slop" if the new bearing was on the outside tolerance, and the shaft or housing was on the large side of the tolerance, the bearings are still allowing the drum to move, and thump.
OR if belt driven, the alignment of the belt is important, if one pulley is out, and the other in, one shaft will be pulling and the other pushing, again a thump.
Something in the bearing/pulley setup has not been discovered bad yet, it takes micrometers and some knowledge of bearing tolerances to resolve this kind of problem.
Think about it, what can thump in a dryer? The tumbler cage. It is most likely that the journal or housings are wore, second the motor may have a front or rear bearing/ housing the same thing, gone bad,
This machine is old enough I would expect to find a worn housing or shaft, either drum or motor,most likely drum, check the alignment of the belt also, but most likely the thump is not cost effective to repair, plus Dad's time which is invaluable.
Start searching the sale sheets, and reading consumer reports, time for a new energy easy dryer anyway.
Sep 16, 2008 | Kenmore 63942 Dryer
Kenmore Dryer Model 417.80042990 problem
Could be just that. Thin coins like that can get into the drum baffles (those 3 "vanes" inside the drum that lift the clothes). It's a simple matter to open the top, remove the baffle(s) and clean them out.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 08, 2007 | Kenmore 63942 Dryer
Roper RES7646KQ Electric Dryer Logo
128 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
