Question about Alpine MRP-F240 Car Audio Amplifier
Can this power a subwoofer and what is the rms wattage
  • 655 Answers
Hello crucible19,
The Alpine MRP-F240 is a 4-channel amp that outputs 40 watts RMS per channel. It is more suited for powering normal speakers, but since it is bridgeable, you could power a small sub by bridging 2 of the channels.
Hope this helps.
Posted on Oct 03, 2009
Watts rms?
It is the root mean square (abbreviated RMS or rms), roughly 0.707 of the peak wattage of an AC source. Crutchfield lists it at >power range: 2-110 watts RMS (450 watts peak power)
Sep 16, 2013 | Kenwood KFC-6986 Coaxial Car Speaker
Just want to know what speaker wattage matches my v12 mrv f705 85 rms x4 channel amplifier?
Use speakers that will handle 85 RMS continuous or higher wattage. I have 200 watt Rockford 6.5s on a 75 watt amp. They sound great with plenty of headroom if I go to a bigger amp.
Nov 20, 2012 | Alpine Car Audio & Video
What subwoofer is compatible with goodmans 14651
Find out through google or somewhere else what the rms wattage per channel is on your amp...Then find a sub or pair of subs that can handle that wattage. Then you will be in business
Mar 14, 2012 | Car Audio & Video
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    What size amp needed with a sony explod player?
    this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
    audiopipe apf1801
    71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
    Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
    Subwoofer and amplifier wattage problem
    No it will sound good if you can put an amplifier with 500 watts rms it will sound better
    Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
    What wattage amp do I need to get good sound in a toyota corolla
    Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
    Amplifier For Powering Sony Xplod xs-l121p5
    Pump the brakes!
    You need to know the RMS power rating of the sub you are powering.
    Dont exceed the RMS power rating of the sub by more than 25%.
    If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
    Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
    Bottom line, know your RMS numbers, not Peak.
    Byron
    www.distinctbeat.com
    Dec 06, 2009 | Sony Car Audio & Video
    Subwoofers
    This will depend on the amplifiers capabilities.
    I will give 2 different scenarios.
    #1 Stereo configuration
    If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
    Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
    #2 Mono Bridged mode.
    If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
    Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
    So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
    For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
    Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
    Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
    Alpine MRP-F240 Car Audio Amplifier Logo
    312 people viewed this question
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    Tygh Duval
    Tygh Duval
    Jaime Hernandez
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
