Question about Brother HL 5250DN Laser Printer
Cannot print as only toner light stays on.
All lights come on and then only toner light stays on.
    Scholar:
  • 92 Answers
Means you need a new cartridge is my best guess..
Posted on Oct 02, 2009
SOURCE: BROTHER 2030 TONER LIGHT STAYS ON CONTINUOUSLY
I had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Posted on Oct 24, 2007
bluegreenash
  • 661 Answers
SOURCE: Brother HL-2070N
did you remember to remove the seal on the toner cart? this is a breakaway tab usually on the side, this when pulled removes the plastic seal,(from inside the cartridge)
Posted on Aug 17, 2007
SOURCE: Toner Light stays on after new cartridge installed
@Shortcutls
Thanx a lot. my printer problem is solved by following your steps.
Thanx again.
Posted on Feb 25, 2008
SOURCE: replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Posted on Aug 26, 2009
SOURCE: Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
Posted on Nov 27, 2009
Testimonial: "Thanks!"
The exclamation and the toner lights are steady on yellow and i can't print
needs pcon or toner replacing exausted hence toner light and ! mark and will not print por before changing or it will stay the same
Nov 17, 2011 | Lexmark E260dn Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Toner light and Status light stays on
well it may need to be completely reset or you could try seeing if it is jammed or stuck in some way
Sep 11, 2009 | Brother HL-5240 Laser Printer
I have changed the toner in my printer and the toner light continues to stay on/won't print. I tried changing the drum and still the toner light stays on/won't print. I tried opening the toner door and...
No guarantee this will work but I refilled toner on my Brother 5170 and it only worked after making sure the old stuff was completely out. After removing the little plastic plug, I tapped out the toner repeatedly on the side of a trash can (like 50 times) then took a shop vac and let that **** out whatever toner was left. It really seems to be important for some reason to rid the cartridge of ALL old toner before adding the new stuff. Hope this helps!
Feb 23, 2009 | Brother HL-2040 Laser Printer
Brothers HL 1240 Alarm light on
Pull the drum out the front door, remove the toner cartridge and check for any paper and remove it.
Make sure there is toner in the toner cartridge. Look at the lights on the printer. Look at the labels beside them. The label "Toner" will have two lines going to two lights. If those two lights are on when you try to print, you are out of toner. But a now toner and install it in the drum. Install the drum back into the printer.
If not, look at the drum. At the rear top is an opening across the whole drum. Look inside it, you will see a metal grid. That grid must be clean or it will cause small sparks. These sparks will cause a false toner empty error. Buy a can of compressed air from Best Buy (or wherever). Use this compressed air to blow clean the grid. Move the small blue tab at one side of the opening ti the other side and back again. Reinstall the drum and try printing again.
If neither of those help, write back and let me know what lights stay on when the printer stops.
Sep 06, 2008 | Brother HL 1240 Printer
Light copies
You may have your machine set to print in "toner save" mode. Check your machine settings by printing a list. Also, some generic toner cartridges have too much polymer in the mix and will print light copies. If you change back to OEM toner, you may have to change the drum too, as the extra polymer stays in the drum unit and weakens the mix.
Jun 04, 2008 | Brother IntelliFAX 2800 Laser Fax
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Brother HL 5250DN Laser Printer Logo
183 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
