Question about Kwikset 909 909-15 Satin Nickel Smart Code SmartCode Signature Series Touch
No instruction manual
I bought this house and there is no manual to explain how to program a code into it.Change batteries and inspect
  • 4 Answers
There is a full program and instruction manual on Kwikset.com
Posted on Oct 07, 2009
Outdoor light timer by Intermatic in house when we bought it. Trying to program it after changing batteries, but there are no directions for it. how would I get some instructions for it?
1) Model number is unknown.
2) You have outdoor programmable Intermatic timer, and replaced battery.
3) Open following link to help identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
4) If timer does not show on link above, add a comment with clear description of timer and buttons for possible identification and manual.
5) Most battery operated timers require 'reset' after battery change.
Manuals usually say, the battery is replaced and programs remain intact, and then current time has to be set again.
In typical situation however, most timers lose functionality with battery change. That's why timer is reset, and then reprogrammed.
6) If functionality is not restored after battery change and reset, then timer has gone bad.
7) Newer Intermatic timers have 'lifetime' warranty against workmanship defect.
Older timers have 1 year warranty.
8) Electronic timers, low voltage power packs, plus electronic water heaters, and electronic water softeners and treadmills etc are each susceptible to power surge from nearby lightning and also from simple power outage.
Not always necessary, but safest to unplug outdoor timer during storm event and with circuit breaker trip, or power outage. Plug back in after power is restored or storm is over. This is true also if timer is on GFCI, and breaker trips. Unplug timer and then reset GFCI.
Add a whole house surge protector to main breaker panel. This gives 1-time protection from surge event.
9) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Hardware & Accessories
Hello I bought a car used and had to change the steering wheel and had to unhook the battery. After I hooked it back up my radio locked out and my manual said I needed the code to reset it but I don't have...
call a GM dealer, ask for service department. briefly explain your malady, they only hear this dozens of times per day. either they can give you a code or send you to a website with specific instructions.
Apr 11, 2011 | 1998 Pontiac Grand Prix
How do I reset my code for this lock. I bought house with this lock and there is no manual on how to reset code. Please help
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Mar 07, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
Can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
Jul 22, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Lost a tv remote in a fire. Bought a universal remote but cannot fine a code to program it.
read the directions at the part where it says manually program, you have to do certian functions then push the channel up and down until tv responds then its programmed, this is actually finding the code as you go, instructions will explain it all because ech universal is just a little diff in its manual process.
Dec 18, 2009 | Vizio L32 32 in. LCD HDTV
How to change code
Take the cover off the back of the unit where you are supposed to install the batteries. The instructions should be inside the cover. Hope that helps.
Jun 03, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I just bought a Harmony 670 Advanced remote, but
check out the battery.other wise ir sensor problem.
Mar 08, 2009 | Logitech Harmony 670 LCD Remote Control
I can't program my thermostat
use the mode button till program shows up then adjust temp with arrows and hit set
Nov 14, 2008 | Hunter Heating & Cooling
MV19L2W tv/vcr
in the manual that came with the new remote control, in the section that explains how to program the codes, there should be instructions on how to search for codes not listed under tv codes. it may take a little while to find, so try to be patient. if you can't find it that way take it back to where you got it and explain your problem. they should take it back and let you get a different name brand of universal remote.
May 10, 2008 | Toshiba MV19L2 19 in. Combo
Kwikset 909  909-15 Satin Nickel Smart Code SmartCode Signature Series Touch Logo
594 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
