Question about Canon EOS 40D Digital Camera
Suddenly the camera will not turn on. It worked fine only minutes ago. Battery is charged, installed correctly, and I have tried other charged batteries. The CF card is installed properly and the door is closed.
  • c1obrien Oct 02, 2009
    Thanks! I'll check it out!
    Top Expert:
  • Canon Master
  • 75,005 Answers
U need to verify the battery is indeed good, just because it is charged doesn't mean it is any good, this is the common cause of this problem, get a volt meter and measure the battery voltage, it should be approx 3.90 volts DC scale of meter, if u are unsure any radio shack will test it for you free of charge, also have the charger checked they do fail, if both battery and charger check ok the camera has failed, this would be in the micro circuit that boots the camera on, there are no parts that can be serviced on this camera by the consumer, u can't even get them apart with special minature tools, if the camera itself is the problem call Canon USA (I assume u are in USA) and ask is they offer an exchange program, most camera makers do, if not then you will need to inquire into the nearest factory authorized repair center.
Posted on Oct 02, 2009
MY Hc v110 Camcorder is not turning on. I've checked the battery and that's completely fine. HELP
How do you know the battery is actually "fine"? Did you put a meter on it or have you tried another battery? The battery can show to be charged but not working if it's gone bad.
Also, try removing the battery for at least 60 minutes, check and clean the contacts on the battery and in the camera, then install the battery and see if it will start. Sometimes removing the battery for some time will reset the camera.
Dec 29, 2014 | Panasonic Video Cameras
I have a Finepix xp50, with a fully charged, correctly installed battery, that won't turn on. It worked intermittantly for awhile. We have 3 batteries for this camera thinking it was the battery
Be sure your battery is in the right way. Try reversing it. My battery has 3 rounded corners and one square corner. The square corner goes against the latch.
Aug 21, 2012 | Fuji Finepix F50FD Digital Camera
Nikon S3000 dosent turn on
Have you updated the firmware? According to Nikon, when the Rechargeable Li-ion Battery EN-EL10 is inserted in the camera and charged, charging sometimes did not stop after the designated amount of time had passed. Usually, you'll receive the message "Battery Exhausted" if this is the problem... but you could also have a completely dead camera as well.
See Nikon's website, download updated firmware to your camera and install a NEW battery. http://support.nikonusa.com/app/answers/detail/a_id/16873
Nov 29, 2011 | Nikon Coolpix S3000 Digital Camera
My camera keeps turning off and turning on, the lens open and close suddenly and nothing appears on the screen, except for a short period of time i can see the image in the screen. i have take out the...
Hi, Have you tried a different battery as it sounds like the battery may be a lemon? Also depending where you bought it you may be able to return or exchange it still.
Aug 29, 2011 | Olympus STYLUS TOUGH6020 Digital Camera
Canon 60d will not turn off. worked fine a minute ago. it's new. nothing responds now. battery fully charged. lcd display on, but not on live view. what to do?
Take the battery out for 60 seconds and then re-seat it back into place and power up the camera, if this fails! return it since the item is under warranty.
Feb 28, 2011 | Canon Cameras
Won't work
Are you sure the battery is charged ? i have seen many Casios that do not recharge fully if the camera is left for long periods with the battery flat - the battery goes below the 'float' level and the charger does not work. See if you can borrow another battery or use a generic charger that does not look at the battery level. A good camera shop should be able to help.
Jun 09, 2010 | Casio Exilim EXZ75 Digital Camera
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 25, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
NO Power
Possible causes Solutions
/ Corrective Actions
The power does not
turn on.
The ViviCam 6300
suddenly powers down.
The image is not
captured when the
shutter button is
pressed.
The flash does not fire.
Continuous shooting
is not possible.
Cannot transfer files
over a USB connection.
* Load new or fully charged battery.
* Load the battery in the correct direction.
* Close the battery cover correctly.
* Properly connect the AC power
adapter.
* Set the option of Auto Shut Down to Off.
* Turn the power back on or charge the
battery.
* Rotate the mode dial to A , P , SCENE
, Tv , Av or M.
Transfer the desired files to your
computer and then delete unnecessary
files, or use a different memory card.
* Select a different flash mode.
* Select [Single] in the capture mode .
* Insert a new SD memory card.
* Check all connections.
* Install the USB driver on your computer.
* Turn on the ViviCam 6300.
* The battery has run out.
* The battery is not oriented correctly.
* The battery cover is not closed properly.
* The AC power adapter (optional)
is disconnected.
* The function of Auto Shut Down in
Jan 25, 2008 | Vivitar ViviCam 5386 Digital Camera
Canon EOS 40D Digital Camera Logo
71 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
