Question about Dell Office Equipment & Supplies
My dell projector 1100mp projects upside down. The remote does mot work to get the menu. How can I get the projection flipped?
  • 5 Answers
SOURCE: Data Projector projecting upside down
If you go onto your menu and click on "setup". Press orientation and select the right one for your projector. It allows you to choose whether your projector is on a table top or ceiling mounted etc.
Posted on Feb 19, 2009
wellss123
  • 4 Answers
SOURCE: Viewsonic PJ513DB DLP Projector projects upside down
Double check which menu item you are expecting to find the orientation. It might even be under 'image', 'settings', or its own button not in the menu, Jon.
Posted on Feb 24, 2009
  • 105 Answers
SOURCE: lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
Posted on May 29, 2009
SOURCE: Can't access Menu
On the PB6100 you must have a input signal to access the menu.
Posted on Jul 18, 2009
projdoc
  • 2237 Answers
SOURCE: projects upside down
go into the menu and reset the setting to factory default.
Posted on Dec 17, 2009
How can I flip the screen without the remote control?
Does this projector have a small button on the back for menu? If so then you can access the menu using this. I believe it is under Option 2 and then will be ceiling on or off
Jan 12, 2016 | Panasonic PT LB50U XGA 1024 x 768 LCD...
Upside down picture on Vivitek D530
Hello
Check the Projection setting on the Installation I menu of the OSD
Feb 11, 2012 | Vivitek D530 Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
How do i reverse the upside down screen
You turn the unit upside down.
http://support.dell.com/support/edocs/acc/2300MP/en/usage.htm
Go to the menu.
Go to management.
Go to Projection Mode.
Front Projection-Desktop: If you want it to project right side up off a table.
Front Projection-Ceiling Mount: If you're hanging it off a ceiling.
Jun 24, 2011 | Dell 2300MP Multimedia Projector
I want to hang it on the ceiling face down, but the it projects upside down!
almost all projectors have a menu setting to allow the image to be flipped when ceiling mounted. Be careful not to confuse this with the rear projection setting which it is also likely to have...this makes a mirror image.
Just go in to the menu using the remote or the buttons on the projector and you will find a setting in there
Apr 05, 2011 | Optoma TS400 Multimedia Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Menu
Hi paulveldt
Very easy ! Simply go into the menu and look for the subfolder that will either read Mirror or Flip Image. Scroll down to it and press left or right until the image is back to normal.
A mountable Projector can project flat fronted ( on a table ) upside down ( on the ceiling ) rear ( from behind - on a rear projection screen ) and upside down from behind ( from the ceiling onto a rear projection screen )
This should do the trick !
Thanks for using Fixya !
Apr 30, 2008 | NEC VT676 Multimedia Projector
156 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
