Question about Canon i860 InkJet Photo Printer
I have 4 x6 printer paper and the printer only shows standard 81/2 by 11
  • dadb400 Oct 02, 2009
    It turns out that the 4 x 6 photo paper has a extra tab that makes it too long for the paper holder. That causes the printer to jam and not be recognized. Problem solved. But I wonder why HP put the extra length tab on the paper?
    President:
  • 2,306 Answers
If you use windows photo gallery to print, it will allow you to set the paper size and type, otherwise in your control panel/printers and printing preferences you can set the 4x6 paper size.
Posted on Oct 02, 2009
Printer shows standard top bin full
Where the paper exits, there should be black tabs that lift up each time a page exits. They might be stuck in the up position, or possibly broken. Usually caused by aggressive removal of a paper jam.
Sep 24, 2014 | HP LaserJet 5200 Printer
When i on the printer then "standard top bin full
Just check at upside where paper iscoming out after print, there you can see the two black flips to monitor the paper out position, this flag sensor got dusty this error apprears, remove back cover, you can observe left side this sensor, just clean it..
Aug 25, 2011 | HP LaserJet P3005 Printer
Using Lex. 4'x6" paper, my 901 is not
To properly lay the 4 X 6 in paper in the tray, please follow the steps below:
  • Pull tray completely out of the printer.
  • Move the paper guides to the sides of tray.
  • Use the photo paper outline on the bottom of the tray to help you position your paper.
  • Load your paper.
  • Adjust the paper guides to rest gently against the left, right, and bottom edges of the photo paper.
  • Insert the tray.
Make sure the correct print setting is configured before printing your file. With your file open, click File > Print > Properties > From the Paper Size list of the Print Setup tab, select 4 X 6 in. Click OK to save the setting. Click OK again to print your file.
Jul 24, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Can't get perfect test pattern,even after jet cleaning x6
If your test pattern has bleeding, it could be the paper you're using. Try using a higher quality paper of 24lb or higher.
Feb 28, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Epson R2400 letterhalf borderless printing
No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
Jan 23, 2010 | Epson Stylus Photo R1800 InkJet Printer
My printer Lexmark T634 is showing "remove paper standard bin"
What your printer is telling you is that it thinks or knows that the top exit tray for the paper is full. This is the tray that is moulded into the top of the printer.
This caused by two things. It is actually full or the Bin Full Actuator is out of position and forcing the error condition.
Look at the standard bin. Over to the top at the top left corner there should be finger (almost the same as paper clip) hanging down. If it is not there, then it is more then likely that the finger is jammed up.
Don
Nov 04, 2009 | Lexmark T634 Laser Printer
I am trying to print 4 x 6 photos, and have set all of the settings to 4 x6, but I the printer keeps printing part of the photo on the entire 4 x 6 area of the paper. Could you help please!!! Thank you.
I belive you are saying the printer is trying to print say an 8X10 picture on you 4x6 paper. If this is the case, the software is not being set correctly for the size of paper.
Mar 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
How do I print 4x6 photo on 8 1/2 x 11 paper?
Easiest is to open your photo with 'Windows Picture and fax viewer', follow the prompts, and the final window will give options to print "full page', Wallet size" 4"x6", etc
Mar 01, 2009 | Epson Stylus NX400 InkJet Printer
Standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Feb 26, 2009 | HP LaserJet P3005 Printer
Canon i860 InkJet Photo Printer Logo
54 people viewed this question
old marine
old marine
