Question about Dualit Kitchen Appliances - Others
Is not hot
My toaster does not heat up. It is getting electricity and winds down but no heat.
  • 403 Answers
This a good indication that your elements have gone bad. Having it plugged in could cause a electrical fire. Unplug the unit. How old is it. With what a toaster cost if not under warranty get another one and trash this one. It's not worth trying to fix unless under warranty. Hope this helps. Let me know what happens and if I can help you with anything else.
JimmyC
Posted on Oct 02, 2009
My ET-26 Hobart toaster will not cook 2 slices on either side unless both handles are pushed down !
That is strange, both sides are completely seperate electrically. Problems I have seen in the past are that some Hobart toasters are bun toasters and only toast one side of the bread. If that was the case you could look down into the toaster and see that only one side of each slot has a heating element. The other common problem is when someone changes a 220 volt to a 110 volt toaster by running the elements in series instead of paralle. at the terminal block. I am stumped on this one. I can't think of a fix for that. I am going to look at the wiring diagram again. If your question is still up, I will get back to you.
Sep 20, 2010 | Hobart ET26 – 4-Slice Bread Toaster
Starter won't work when engine is HOT, only later when cooler. Cables are tight and clean, BATT. is full, ign. lites work, windows go up& down
The armature which is the shaft with the windings inside the starter has swollen up from age and heat. Upon cooling down in a few hours the armature will run freely again. When hot the metal housing the windings wrap though is the part that expands. From age and heat metal gets weaker, & much weaker as days goes by. You can simply replace the starter or if your mechanicly inclines remove the armature and install it is a lathe or a drill press and file it down. Do not file on the windings or it will short out. I suggest to purchase a rebuilt starter instead for the fields are magnets which get weak from heat as well
Jun 29, 2010 | 2002 Mercury Sable
The toaster made a 'pop' sound when I was toasting bagel slice,.., and then it started to smell likie 'electrical burning'. After I unplugged it, cleaned and checked it,... it no longer would operate. The...
Looking for the thermistor is the correct first step. Depending on how the heating elements are wound, mine failed at a bend that wrapped around the panel supporting the element windings. Vaporized a small segment. Unfortunately, i wasn't able to find a replacement heating panel. I suggest you use an ohm meter to check continuity on the heating elements. There will be some resistance. If you find the failed circuit, you're really stuck for repair methods, most elements are not designed to be repaired without the correct welding tools. Good Luck.
Mar 16, 2017 | Sunbeam 3822 2-Slice Toaster
How do a toaster heatingelement work
The toaster heating element converts electricity in to heat energy through the process of Joule heating effect. the electric current flowing through the element encounters electric resistance, resulting in heating of the element.
Sep 13, 2009 | Kitchen Appliances - Others
Right side only one heating element works very hot, when should the heating element be replaced.
You can repair the other side heating element in a electrical shop or by ur self if u have the skills. Mostly the element breaks of due to food hitting at it when ejected or inserted.
Thankyou
Appreciate a good rating from you.
Aug 01, 2009 | Toastmaster TP424 4-Slice Toaster
Goodman ez 1425 blower works but no heat
It has electronic ignition. no pilot light.. it uses a hot surface ignitor to light the burners. this device gets red hot (just like looking down into your electric toaster). this hot cherry red device lights your burners
Feb 21, 2009 | Goodman GMS90703BXA Heater
Toaster won't stay down but does heat
I had the same problem. I opened up the toaster and found that the electromagnet that holds the plastic clip to keep the toaster down had a tiny crumb between the magnet and the metal plate. I cleaned the magnet and it is working fine again. We spent 6 months burning toast by holding it down with a chopstick wedged between the lever and finally took a shot before I went to buy a new one. Took me all of 15 minutes.
Jul 08, 2008 | Breville CT20 Retro Classic 2-Slice...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Another problem comes up....
You definitely have a problem with the hold down circuit. You will need a DMM. If you don't have one they are fairly inexpensive now and with a little reading of the instructions you should be able to master their use. Look for a fusible resistor. It should be a small shiny canister, pointed on one end flat on the other, with metal leads on each end and inline on the wire to the hold down mechanism. Once you find this, with the DMM on resistance setting (continuity), check across the device. If the DMM says infinity, in other words it shows a 1 and the display never changes, this is your problem. Replace it with a new one. They protect the device from runaway heating and are set to open at predetermined temps. Replace it witht the same rated device. Available at most electronic stores. The rating should be in centigrade (such as 160, 180, ect). This should solve your problem. You cannot solder the thermal fuse in as solder will melt when the toaster gets hot. It must be crimped to the wire. Sounds like your almost there. Good luck.
Jul 20, 2006 | Toastess TT-415P 4-Slice Toaster
Kitchen Appliances - Others Logo
102 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
