Question about Acer Aspire® (ASL-100UA380A) PC Desktop
Acer Aspire L100 does'n start. no lite in front pannel. Power supply has 19 volt and getting to motherboard
    Genius:
  • Acer Master
  • 1,274 Answers
Okay so 19 volts getting to the board, no boot, this could be a few things make sure the mobo is securely grounded (some boards are picky) make sure that all the cables (20 pin connector and 4 pin connector if there) are connected all the way.
Posted on Oct 03, 2009
L100 desktop
Lost a power cable?
Like it was walking down the street one day, and the power cable fell out of it's pocket?
Or do you mean came loose?
Or in YOUR estimate, that one power cable coming from the Power Supply, is bad?
The first one I was trying to be funny.
I'm serious about the last two.
http://www.geeks.com/details.asp?invtid=ASL100-UA380A-R
Hmmm, okay let's try this another way,
(Notice I didn't even go to Acer Support. With the info they give the consumer, it isn't worth the trouble. Also tells you a lot about this computer company.........)
http://www.ebay.com/itm/Acer-Aspire-L100-Motherboard-MB-S6909-003-MBS6909003-/120919471509?pt=Motherboards&hash=item1c275cb595
Oh, I see................
http://www.amazon.com/Acer-Power-Aspire-Adapter-Supply/dp/B004PYZSCC
I just got schooled.
Don't believe there are any power wires inside to connect, Christina.
Power is from an external power supply, that plugs into the computer.
(Like a laptop)
The only wires in my estimate, is;
A) The small audio wire from the optical drive (CD/DVD drive) to the motherboard, (Close to the Blue VGA port)
B) The Front Panel wires,
C) USB Front Panel port wires to motherboard
D) Media Card Reader wires to motherboard
E) Harddrive and optical drive data cables to motherboard. (One each)
(The front of your computer is the Front Panel)
Computer not coming on?
See if the external power supply is good.
Voltage coming out is supposed to be 19 Volts DC.
The plug end on the external power supply;
The center hole is the Positive ( + ) connection.
The cylindrical metal shell on the outside, is the Negative ( - ) connection.
Multimeter positive ( Red) probe lead goes to center hole.
Negative ( Black ) probe lead touches outside cylindrical metal shell.
Multimeter positive (Red) probe lead, plugs into red hole on multimeter, marked DCV.
Negative (Black) probe lead only has one hole (Black), to plug into.
Function knob is set to DC Voltage. DCV.
If just a symbol, the symbol is a dotted line over a solid line.
If more than one scale, set it to the 0-50 Volt scale.
(0 to 50 Volts ]
An economical multimeter is about $5 to $12.
Auto parts stores have them. (Although probably more expensive)
I have seen them on checkout aisle racks, at major discount stores.
While checking the AC adapter, have an assistant gently wiggle the cable, from the AC adapter TO laptop.
See if the reading on the multimeter fluctuates. If so you have a broken wire in that cable.
Have the assistant also gently wiggle the power cord.
Or take down to nearest 'Mom and Pop' computer shop, (Small store), and have the resident tech check it for a few bucks
Could also be the Power On switch.
This is located inside the plastic assembly, of the power on button.
They go bad, and do not leave a forwarding address ;)
Post back in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | Acer Aspire L100 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
    You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
    Aug 05, 2010 | Acer Aspire L100 PC Desktop
    The acer l100 does not power on at all no lights or fan running
    If the computer is not starting then and the power supply is ok then you need to try a different charger. If the problem still exist this may a sign that the motherboard is dead and need to be replace, because when a motherboard is dead it the computer will not receive any power.
    Thank you
    May 16, 2010 | Acer Aspire L100 PC Desktop
    I have ACER Aspire One Model KAV60. Need to Identify Power supply
    There are three adapter manufacturers, the Acer One runs on 30 watts and 19 volts. Below are the specs for the adapters.
    10001081
    DELTA
    30W Adapter DELTA 30W 19V 1.7x5.5x11 Black ADP-30JH BA
    LF
    60003544
    LITE-ON OPT
    30W Adapter LITE-ON 30W 1.7x5.5x11 Black PA-1300-04AC LF
    60002015
    HIPRO
    30W Adapter HIPRO 30W 19V 1.7x5.5x11 Black HP-A0301R3
    Jan 24, 2010 | Acer Aspire One PC Notebook
    We are getting a No Signal on our monitor,
    it should be motherboard problem.
    try to check it nearby service centers
    are you able to hear any beep sounds
    pp
    Nov 21, 2009 | Acer Aspire L100 PC Desktop
    Hello again....i've just discovered within the setup and PC health status that there seems to be a problem with the 12v supply. There are 3 different Voltage meters: 1) 12V 2) 5V 3) 3.3V Alongside these is...
    Having never repaired, or seen an Acer Aspire L100 desktop, I went to Acer Support, and reviews on the internet. (I do repair computers, however, not just Googling info off of the internet here)
    Seems the Acer Aspire L100, uses an external power brick for a power supply. Also looks like they're harder to find than hen's teeth!
    It does seem judging by your findings, that your problem is the power supply.
    A computer power supply put's out three main voltages, (Such as you have seen)
    A.3.3 Volts
    B.5 Volts
    C.12 Volts
    You obviously have a weak 12 volt power rail.
    At this point I would take the power brick to a repair shop. I'll bet it's bad Electrolytic Capacitors, but this is just IMHO.
    Also read where there are problems with overheating issues. Most post that the front door should be kept open, when using the computer. Better make sure the inside of the computer is clean, as well.
    (Computer off, and unplugged from power. Use a can or two, of compressed air for computers.
    Pay special attention to the heatsink under the processor fan, and the processor fan.
    Do NOT keep constant air pressure on the fan. It is only designed to spin so fast. Spinning it faster than it was designed for, can lead to premature failure of the fan's bearings! {If you hear the fan go 'Zing' get the air pressure away from it!}
    BEFORE you reach inside the computer, unplug the power from it. TOUCH the metal frame of the computer case, to relieve your body of static electricity. Static will fry out those delicate computer hardware components. You may not see it, or feel it!
    Zap! There goes your computer!
    Try to gently move the fan blades by tipping them. Looseness in this area means the fan bearings are shot. Replace fan)
    Nov 18, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 will not power up
    Power supply is bad. Replace the power supply.
    Dec 30, 2008 | Acer Aspire L100 PC Desktop
    Open Questions:
    Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
    Jun 21, 2018 | Toshiba Computers & Internet
    See all Acer Aspire® (ASL-100UA380A) PC Desktop Questions
    Acer Aspire® (ASL-100UA380A) PC Desktop Logo
    98 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
