Question about Kenmore Washing Machines
Motor runs but does not agitate or spin. - Kenmore Washing Machines
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
if you can hear the motor but it neither agitates nor spins, the problem points to the Motor Coupler.
This is a three piece unit that fits between the motor and transmission and acts as a fail safe.
Following is a description of how to remove the cabinet of a top load and access the coupler.
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
If the prongs on the plastic pieces are damaged or the rubber piece between the plastic pieces on the motor and transmission is destroyed, the motor cannot provide power to the transmission for agitating or spinning.
It's a relatively inexpensive piece and easy to replace.
Posted on Oct 02, 2009
Machine filled with water then stopped running
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Apr 07, 2015 | Washing Machines
Motor on wash cycle does not spim
??? wash cycle is not suppose to spin only agitate, most machine have a dual motor function, motor runs in 1 direction for wash then in another direction for spin. do u mean it does not go into spin? if so need to check the tranny and the clutch, the motor coupler in some cases and if its not agitating washing may have bad cam dogs in agitator, or bad water pressure switch, some times a bad door switch will not allow spin or agitation?
Sep 27, 2014 | Whirlpool Cabrio WTW6200VW 4.5 Cu. Ft. Top...
My washer door is locked with the motor running but no water coming in and the tumbler not tumbling. I can only turn it off if I unplug it.
Jul 25, 2014 | Whirlpool Duet White Front Load Washer -...
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
AGITATOR WILL NOT SPIN, WATER WILL DRAIN BUT NO SPIN
Does your motor sound like it is running in the agitate or spin cycle or is it quite? If the motor makes no sound, then you need to replace the lid switch with this part.
If you hear the motor running in the agitate or spin cycle but you don't see any action, then replace the motor coupler with this part.
Dec 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Fills with water..doesn't wash..drains and spins..does the transmission spin in direction and wash in the other? in other words does the motor run one direction to spin and rev. to agg/
Yes it does reverse. If the motor is running in agitate pull off the agitator and check the agitator drive (bell) (white plastic bell shaped) on top of the agitate shaft is not stripped. You should not be able to turn. To remove the agitator fill first about 8 in of hot water, drain and pull up on agitator with fingers under the bottom or a belt.
Nov 22, 2010 | Hotpoint -Ariston VVSR1030HWO Top Load...
Doesn't agitate or spin but makes loud motor sound
check your motor coupling, it is between the motor and tranny
Feb 17, 2010 | Washing Machines
Won't agitate or spin
If you mean that when the unit should be agitating or spinning the motor is running, and you lift the lid causing the motor to stop running, it sounds like the coupler.
Mar 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Matag Atlantis MAVT634 will not agitate
Does the motor start and run for agitation with the belt connected?
Jan 29, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
