Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Pixma 860 faxing with adf wont work only through platen
5 Suggested Answers
komguy
  • 2306 Answers
SOURCE: My ADF Scan does not
There is a small black lever toward the rear where you place the documents to scan. if it is broken or missing it can't see when you place a paper there to scan. If you can see a rectangular hole in that area with nothing in it, you will have to take apart to find and replace the sensor lever.
Posted on Jun 30, 2009
  • 3278 Answers
SOURCE: can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
Posted on Oct 04, 2009
old marine
  • 1991 Answers
SOURCE: Scanning a document from the ADF results in a line
Lift the scanner cover so that you can see the platen glass. Look to the left of the large sheet of glass and you will see a narrow strip of glass. This is the area used to scan documents fed from the ADF. Make sure that this glass is very clean. Use a damp cloth to clean any dirt or buildup.
Posted on Feb 10, 2010
SOURCE: Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Posted on Apr 15, 2011
Trying to use adf but tells me to put original on platen
You need to check the settings for scanning. The machine wants to use the platen because that is what it has been set up to do, or you are using a sheet size the machine doesn't know about. Again go through the scanner settings both on the machine and any attached computers.
Sep 04, 2016 | Canon Pixma Mx459 All-in-one Inkjet...
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
Apr 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
The fax is received by the other party but we receive an error code J72. There is no jam
Dear
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Thanks.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
Jun 03, 2011 | Canon PIXMA MX340 Wireless Office...
Need instructions on how to send fax, it seem as though we are not following the correct steps
Solution: Sending faxes on an MX310
Sending Faxes
The operation flow of sending faxes is as follows.
  1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
    Platen Glass
    1. Lift the document cover (1).
    2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
    3. Gently close the document cover.
ADF
  1. Remove any documents from the Platen Glass.
  2. Open the Document Tray.
  3. Load the document in the ADF.
    Load the document with the side you want to copy, scan, or fax facing up in the ADF.
  4. Adjust the Document Guides to match the document width.
  1. Press the button.
  2. Adjust fax settings as necessary.
  3. Start faxing.
    1. Dial the recipient's number using the numeric buttons or coded speed dialing.
    2. Press the button for color sending, or the button for black & white sending.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
    3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
    4. If you have only one page of document to scan, go to step 5.
    5. Press the same button as you pressed in step 4b.
    6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
  4. Press the button.
  5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
  2. Press the button.
  3. Press the (left) or (right) button to select the contrast.
  4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
  5. Press the button.
Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
  2. Press the button two times.
  3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
STANDARD:
Suitable for text-only documents.
FINE:
Suitable for fine-print documents.
PHOTO:
Suitable for photographs.
Return to Start Faxing
Back to the Top of the document
Dialing the Coded Speed Dial
  2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
  3. Press the button for color sending, or the button for black & white sending.
    Note:
    * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
Feb 04, 2011 | Canon PIXMA MX310 All-In-One Printer
Does canon pixma mx 310 work faxing page up or page down?
When using the ADF load the document with the side you want to copy, fax or scan facing UP in the ADF.
When using the platen glass load the document with the side to be copied, faxed or scanned facing DOWN on the platen glass.
Trust this helpful.
Please vote.
Dec 15, 2010 | Canon PIXMA MX310 All-In-One Printer
Scanning a document from the ADF results in a line down the middle of each page scanned. Scanning from the platen (not using the ADF) works fine
Feb 10, 2010 | Canon PIXMA MX7600 Multifunction inkjet
When I make a photocopy I get a dark vertical line down the page. In fact, now I get two dark lines. It has something to do with the scanner, because it happens when I send someone a fax as well. ...
Do you use the automatic document feeder (ADF) when you photocopy and fax? Do you use the platen (lift the cover up) when you scan a document? If so, you probably have some dirt or foreign material in the ADF scanner area, which is a thin glass area to the left of the glass platen. Clean this area with a damp cloth and dry it before trying again. There is a plastic strip covering this area, and if this is scratched it can be removed and replaced.
Jan 19, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Every Fax we send has stripes going down it making it hard for the receiver to read our faxes. It doesn't happen when we receive fax, print or make copies.
You say it makes copies without the stripes. Do you use the automatic document feeder (ADF) when you make copies, or open the top and lay the paper on the platen? If you get stripes when using the ADF, the ADF scanner area needs to be cleaned. It's the smaller glass area to the left of the main platen glass. Use a damp cloth and remove any dirt or debris.
Jun 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
old marine
old marine
