Question about Jenn-Air JMW8527C Electric Double Oven
Jmw8527AAb Jenn Air Electric Wall Oven
The oven fan comes on when the oven is turned off. The only way to turn it off is to turn the oven on and let it run for 10 minutes and then ithe fan shuts off. Then I turn the oven off and it's good for another few hours.
    Scholar:
  • 146 Answers
Has anyone done any repairs to the oven lately? It sounds like it's working in reverse. The fan is supposed to come on about 10 minutes after the oven is turned on. The reason I ask this question is if someone did work on it they could have wired the fan relay wrong. If not you have a problem with the oven fan relay. They occasionally short and it wll cause them to run the opposite way they are supposed to.
Posted on Dec 21, 2007
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
I have an older jenn air model ww30430 and I cant get the fan to turn off or the upper oven to work. any suggestions
if your unit is switch position is the upper heating element is have convection? you cannot turn off the fan,but if your unit have separate option to choice the other option to oparate separately the upper heating element this one can be use.
Dec 24, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Error message on JJW9530DDS Jenn-air wall oven is 4d21
no/low cooling fan rotation (No RPM) single cavity or upper oven - check connection at cooling fan if ok, replace blower - DO NOT REPLACE CONTROL
Mar 06, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Our kitchen Aid Superba Double Oven makes noises when we turn it on and also as it cools down. It sounds like a fan-type noise. How can we fix it?
We had the same problem. It is the fan in one or both of the ovens. we had a repairman come out because the ovens have to come out of the wall. It was a quick fix.
Oct 04, 2009 | Jenn-Air Electric Double Oven
Microwave on counter making wall oven change
ok the microwave has magnetic fields that may be messing it up only way is to turn microwave off or move it at lease 1 meter away from oven let me know how that goes's for you
Dec 30, 2008 | Jenn-Air 27 in. Electric Single Wall Oven...
WW30430
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JMW8527C Electric Double Oven Logo
347 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
