Question about Ricoh Aficio GX5050 GelSprinter InkJet
How do I name a document at the printer when I am scanning?
When i scan in invoices how do i save them in documents and name them according to invoice # and last name.
Open scanned document, right click on document, click on save as, type in invoice # and last name.
Feb 02, 2016 | Epson WorkForce WF-3640 Wireless Color...
How do you scan
with my cannon i have to go to start menu, select windows photo gallery from all programs - once open in top bar is file with down arrow click- see import scanner printer click- your printer should be listed click import - new screen will open- document type should be document not photo- color format grey scale color etc, i leave color, leave image a jpeg - then click scan after setting document in printer window, assuming you have a lift open printer, place document face down in the upper left hand corner. click scan - save document with title you want and open email search documents type document name and attach to email.
Feb 09, 2013 | Canon PIXMA MX340 Wireless Office...
X544dn scanning and Windows Server 203
Scanning documents at the printer
1 Load the document into the scanner.
Note: Documents may be loaded into the scanner in multiple ways. For information on the different methods of loading documents into the scanner, see the User's Guide that came with the printer.
2 Touch Scan to Network. If prompted, enter the user name and password used to access the printer. Contact your system support person for login information.
3 Select the destination where you want to receive the scanned document. If prompted, enter the user name and password required to access the destination. Contact your system support person for login information.
4 Some additional job options may be available depending on how the application has been configured. Follow the instructions on the screen to update the options. Contact your system support person for more information on each option.
5 Touch Scan It. Depending on how the application has been configured, you may have the option to preview and make adjustments to scanned pages.
6 To scan additional documents, load the next document into the scanner and select one of the following from the confirmation screen:
• Touch Yes, to same destination to scan the document to the previous destination.
• Touch Yes, to a different destination to scan the document to a different destination.
• Touch No to finish the operation and return to the printer Home screen.
Jul 23, 2012 | Lexmark X544dn All-In-One Laser Printer
AFTER SCANNING A DOCUMENT-HOW DO i ATTACH IT TO ANOTHER
You could "name" the scanned document and put it on your desktop (under C: ) Then after creating the second document "copy" the scanned document to thhe bottom of the second document. Use the right click to copy and then go to second document and click "paste".
May 22, 2012 | Canon PIXMA MP495 InkJet Printer
I have pluged the laptop into ny HP Photosmart C5280 All in one printer scanned the document but wher do I find it on my laptop thanks
Hi
It will store all the scanned files in My PICTURES under MY DOCUMENTS. You will find a folder with name Scanned.
Aug 01, 2011 | HP Photosmart C5280 Printer
I want to retrieve a document that has been scanned and printed so that i print more copies
once you have scanned this document you will have saved it before printing it usually in my documents (most common) if you remember the name of the document you can use/select the search utility click start search type in the name press enter
hope this helps
Feb 24, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
How do I use the scan option on the C6280 to scan a document on my desktop. I can print to the printer but cannot figure out how to set it up to scan
First, make sure all of the drivers for your printer were downloaded from the CD that came with your printer and make sure your printer is connected to your computer and turned on..
Second, if you are using a Windows PC, Click on:
Start > All programs > Accessories > Paint
Third: When the Paint program opens, in the top toolbar click on, File > From Scanner or Camera > then select your printer by clicking on your printer's icon > then click, OK.
Fourth: Place the document you wish to scan on the glass of the scanner and click on: Scan.
The document will be scanned and automatically sent to the Paint program.
Fifth: Click, File > Save as > (name the document) and save it in your Pictures folder.
You can now close the Paint program and open your Pictures folder. Click on the document you scanned to view it.
Mar 29, 2010 | HP Photosmart C6280 Printer
I scanned a document & now can't find it.
Hi kathy_skip
If you remember the name of the saved file, use a search.
Some scanners give the name like scan000,scan001,scan002 etc
If you have no idea what the name was, then scan another document (if you don't have the previous one) and watch the name of the file and folder where it is saved. You may find your previous scan next to it in the same folder.
Best of luck
luciana44
Oct 08, 2009 | Brother HL-2040 Laser Printer
Don't know how to use OCR scan function.
Greetings,
i beleive we have the complete setting detail with us.
1. Press the [Send] tab.
2. Press [Address Book] ([File] or [E-mail] also acceptable).
3. Choose an e-mail address. Press [OK].
4. Press [File Format]. Set to [PDF OCR]. Scan Settings
default to 300 x 300 dpi.
5. Choose [Send Settings]. Add [Name] and [Subject]
to the e-mail.
6. Or choose [Doc. Name OCR] to automatically name
document using initial characters of document text.
7. Press [Done].
8. Place the document on the platen glass or in the ADF.
9. Press [Start] to send document.
Regards,
TechSup1
May 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ricoh Aficio GX5050 GelSprinter InkJet Logo
15 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
