Recoton Advent Advent AV570 Computer Speakers Logo
Posted on Oct 02, 2009
Just had new Vista Service Pack update on my pc and now my advent speakers won't work. Can anyone help please?
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on Oct 02, 2009
Anonymous
Contributor
Level 1:
Answers
25
Questions
0
Helped
5731
Points
69
If you can get on the net just download original soundcard details and re-install drivers
My hp pavilion dv5-1000 sound is not working ive tried every test on the hp website. when i push test button it says failed to test but on the other ones it says its working properly. after all the tests...
Did you do any update? Usually the sound goes off after updating to Windows Vista Service Pack 2. I had the same problem in my laptop. Just reinstall your Sound Driver.
tip
What Does It Mean When Support for My Operating System Ends?
Microsoft Support for Windows Vista (with no service packs installed) ended on April 13, 2010, while support for Windows XP (without Service Pack 3 installed) ended on July 13, 2010. Windows 2000 support ended on July 13, 2010 as well.
There is no Service Pack 3 for the 64-bit version of Windows XP. If you're running the 64-bit version of Windows XP with SP2, you have the latest service pack and will continue to be eligible for support and receive updates until April 8, 2014.
If you are still running a version of Windows where support has ended, it means that version of Windows will no longer receive any updates from the Windows Update or Microsoft Update site. These updates are generally provided for security reasons to help protect the PC from harmful viruses, spyware, malware, and other malicious software. Windows Update also provides new drivers for your hardware that can improve the reliability of Windows.
Hackers love to take a security vulnerability in Windows and exploit it to their advantage. So, if a vulnerability is found in Windows XP or Windows Vista and you are not running the latest service pack, you will not be protected and will be at risk.
How Can I Tell What Service Pack is Installed?
Follow these steps to discover what Service Pack is installed:
1) Click on the Start Button
2) Right-click on either My Computer or Computer (depending on your Windows version)
3) Click on Properties
On this window, it should tell you which version of Windows along with which service pack is installed). It should also tell you whether you are running a 32 bit or 64 bit version of Windows.
Where can I download the latest Service Pack for Windows?
For Windows XP, click on the following link to download Service Pack 3
For Windows XP Service Pack 3 info, click below :-
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
For Windows XP Service Pack 3 download, click below :-
http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4
For Windows Vista, click on the following link to download Service Pack 2
Windows Vista Service Pack 2 info, click below :-
http://windows.microsoft.com/en-us/windows-vista/Learn-how-to-install-Windows-Vista-Service-Pack-2-SP2
Windows Vista Service Pack 2 download, click below :-
http://support.microsoft.com/kb/935791
on Oct 04, 2010 • Computers & Internet
tip
How to obtain the latest Windows Vista service pack?
Introduction:
Windows Vista updates are distributed in service packs. Service packs
help keep Windows Vista current, and they can extend and update the
functionality of your computer. This article describes three
step-by-step methods that you can use to obtain the latest service
pack for Windows Vista. However, before you select the method that you
want to use, please make sure that the following conditions are true:
The service pack is not already installed on your computer.
You are logged on to your computer by using a user account that is a
computer administrator.
The computer on which you want to install the service pack is
connected to the Internet.
If you are not sure that all these conditions are true, please see the
"Before you try to download the latest Windows Vista service pack"
section. Otherwise, select the method that you want to use to download
and install the service pack.
Methods to download the latest service pack
Method 1: Turn on Automatic Updates (Recommended for most users)
Method 2: Check for updates on Windows Update (Same as Method 1 but
not automatic)
Method 3: Obtain the latest Windows Vista service pack from the
Microsoft Download Center (Good to use if the computer on which you
want to install the service pack is not connected to the Internet)
Important: Windows Update may not offer the latest Windows Vista
service pack to some users. This issue can occur for several reasons.
For a full list of causes and resolutions, click the following article
number to view the article in the Microsoft Knowledge Base:
948343 Windows Vista service packs are not available for installation
from Windows Update and are not offered by Automatic Updates
on Mar 28, 2010 • Computers & Internet
Volume problems
Please follow these steps to resolve the issue.
  • Check if the Default Audio Device is changed.
  • Please right click on Volume icon and select Playback Device.
  • Select the Speaker as Default and click OK.
  • Please check if Windows Vista Service Pack 1 is installed in the Computer.
  • Please right click on Computer icon and select properties and check if Vista Service Pack 1 is installed.
If the Windows Vista Service Pack 1 is installed in the Computer, then install the BIOS update to resolve the issue as the Audio may not work properly after installing Microsoft Windows Vista Service Pack 1 (SP1).
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=3618&os_id=28
If the issue still persists, then reinstall the Audio Driver to resolve the issue.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=2798&os_id=28
All the best!!
I have no user handbook, only for Windows Vista in my welome pack, anyone know where to download one? thamks
http://www.uktsupport.co.uk/advent/advidx.htm
goto above link, and you will find all you need there
1helpful
Windows Vista Update
Then it is clear the you do not have a service pack installed. Please download service pack and install it asap.
Speakers not working after vista service pack 1 update
wow vista. after the service update some devices on some models would convert to the vista system. you need to go to devices, and properties and were you audio is click on drivers and revert back if available. if not, you will need to go to the manufactures web site and using your model down load the drivers for your model and keep the file. instal and it should fix your sound problem.
Voice problem in yahoorooms
Can you confirm if your sound devices (microphone, speakers, headset, whatever) are installed and working properly? I don't just mean because Windows says so. I mean have you tested your devices and they are functional? I only know my headset, webcam and speakers work because I physically tested them when I got my new PC.
My acer aspire 5520 laptop wont work after installing windows vista service pack 1
try this >> when you turn on your pc press f8 then choose "last known good configuration"
2answers
Vista messed up speakers
hi Avsandrick
Happy Holidays!
Doing a driver search don't help much, so I recommend 2 things here, wait until MS, make a Service Pack Cd, for Vista, or go to the Altec Lansing Page and see if for your particular model, there are drivers for vista.
other than that, a generic sound driver, could fix the problem.
Top Recoton Advent Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Recoton Advent Audio Player and Recorder Expert? Answer questions, earn points and help others
