Question about HP OfficeJet 7310 All-In-One InkJet Printer
Printer alignment --- documents are printing out missing half of every line. How do I repair?
    Sergeant:
  • 233 Answers
Run the print align program from the HP led panel on the front of the printer. You can usually find this by scrolling through the setup screens.
One will say something like ALIGNMENT.
The printer will also run this exact same program each time a new HP ink cartridge is placed in the machine. Once the lines dashes and color lines are printed out. Their should be an image of a bird at the bottom.
One will look out of focus the other should be near perfect.
If this does not align the print heads the machine may need servicing.
You could try a new black ink cartridge to see if the old one is damaged or clogged.
Posted on Oct 04, 2009
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
Alignment off
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please try this approach:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
My epson stylus DX 5000 prints out with half the lines of the document missing. It's OK for a couple of lines, then odd single lines and half line are missing. I't has full ink cartridges and ve tried the...
I would go to the epson website and download the latest driver for the printer. More comprehensive printing sofware might require the PCL version of the driver. But for regular printing, just download the latest PS driver and see if that helps
Mar 02, 2011 | Office Equipment & Supplies
Got a new Del 720 printer. Using XP. Test page
go to printer properties and do a alignment and it will print like its made to do.
Jul 09, 2009 | Dell Inkjet 720 Printer
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Cannon IP5300 line missing in print
you should open the software or on the printer select clean print cartridges, or align cartridged
Mar 17, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Upper half line missing
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
manual here in link
sounds like the ink cartridges need to be aligned and cleaned there is an alignment button or in software for this
Apr 17, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
99 people viewed this question
Seeker5211
Seeker5211
