Question about Sony KDF42E2000 42" HDTV
Tv will not turn on and on the power light blinks red 3 times
    President:
  • 196 Answers
Change the lamp XL-2400 AND RESET THE LAMP TIMER AFTER.
Posted on Apr 21, 2010
5 Suggested Answers
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Posted on Feb 20, 2008
SOURCE: KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Posted on Mar 31, 2009
Slinteriors
  • 8617 Answers
SOURCE: my panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
Posted on Sep 11, 2009
hawk127311
  • 350 Answers
SOURCE: the tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Posted on Nov 11, 2009
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
The power light is blinking red and the V will not turn on.
Power light blinking red indicates tv got internal problem and went on protection mode.
Please count how many times red light blinks after 3 seconds long pause as it is an error code that has info about defective section in tv and will help me to suggest any solution to fix the issue.
Thanks.
Oct 31, 2010 | Sony KDS-60A2000 60" HDTV
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KDF42E2000 42" HDTV Logo
376 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
