Question about Rheem Water Heaters
I am hearing a kncking sound from my wall (behind the wall are pipes) and it occurs day and night sporadically - appears to be associated with the Power Vent 2 - is there anything I can do
  • 454 Answers
You can install a water hammer arrestor. They are available at the hardware store or your favorite home improvement store. Also, look for pipes which are not secured tightly to the wall studs.
Posted on Oct 05, 2009
I hear a knocking noise behind the wall when I use the hot water. What could it be and how do I get rid of it?
I had something similar, but I would call the noise more like 'ticking'. The problem was that hot water would heat up the plumbing vent piping (plastic) for that bathroom and it would expand and then contract (after shutting hot water off). As the pipe 'grew' it would make noise sliding through the opening in the ceiling header. It seems that builders had stuffed loose fiberglass around the pipe there that served to let the pipe move freely. The fiberglass had fallen out and the pipe was rubbing against the wood and making noise. Stuffing new fiberglass in the opening around the pipe fixed it.
Oct 29, 2014 | Water Heaters
GE Smart Water Model # GE40M06AAG
Bad relief valve or too much pressure in the tank. Does water heater system have a pressure blotter tank that allows for expansion(an expansion tank)
May 05, 2017 | Water Heaters
I have constant 24/7 humming noise (combi boiler i think) the boiler itself is not humming but seems to be in the pipes? mainly kitchen & upstairs, there is "hot spot" for the noise as you go...
If you turn the power off and it's still there then it's not anything electrical in the flat.. it could be transferred noise from another source. I would try locating the sound by listening through a tube to locate the sound more accurately. This method of sound source location is used by old fashioned mechanics listening for engine noises and is very good at finding them..
good luck !
Mar 30, 2017 | Water Heaters
Rattling AFTER water use, while heating
1) Rattling or clunking sound in pipes when water is shut off can be caused by lack of air chamber at the faucet. When moving water is suddenly stopped by faucet turning off, the forward energy of water suddenly stopping will cause pipes to shake. This is because water cannot be compressed. To stop this problem, each faucet has air chamber connected to pipes behind the wall. The air chamber is a simple pipe sticking up with a cap on it. The air chamber never fills with water, so a 'pocket' of air is contained inside the pipe. When water shuts off, the forward motion of water moves up the air chamber where it compresses the air which absorbs the energy, so pipes don't rattle or clunk.
http://www.crsupport.us/images/7b_build_const.jpg
2) Gurgling, popping sound inside tank is caused by sediment build up.
http://waterheatertimer.org/How-to-clean-sediment-out-of-water-heater.html
3) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 28, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have the exact same problem, house is only 6 years old, two handel faucet, Ive turned off the cold side to eliminate it, turn on hot and have to run at full blast and it takes a full 10 minutes to get to...
You have a clog in the water line?
Or a faulty check valve or mixing valve?
Add a comment and say how you fixed the problem, or add more information about size of pipes.
It seems like the cold water is getting into the hot water line somehow. There is no other explanation, as much as I can see from 800+ miles away.
If you have crossover on a single-handled faucet where the cartridge is bad, that can cause this problem.
Slab house can have plumbing in attic. It can be a chore to drop poly pipe down into walls, but it can be done with angle drill. Assuming walls are 8 foot high and pipes can be easily dropped to sink level where the sheetrock is removed and new pipes tied into sinks and tubs.
This kind of DIY project would take a couple weeks working a few hours each night when temps cool off, depending on size of house and number of affected faucets.
I live in Houston on a slab and ran my pipes in the attic when I built the house. Of course I worry about broken pipes collapsing the ceiling and filling the house with water, which happened to lots of homes one year when temps dropped to 4 below. I was in the painting business at that time, which was a boon to business for a few weeks.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Dec 17, 2010 | Laing Thermotech Autocirc Undersink...
Too much water draining from Vulcan Electric H/W relief valve.
Dear Julie. Do you have an expansion tank installed? If so it is probably waterlogged. If you come home shower etc. use lots hot water then go to bed or leave the cold water in your tank heats and expands as it heats. In the old days a toilet ballcock valve would relieve this pressure but modern toilets with diaphragm valves wont so the pt valve relieves pressure. Installing an expansion tank on the cold water line near the heater will absorb the extra water & stop the pt valve from activating.
Dec 29, 2009 | Water Heaters
Bosch water heater lines clogged with pipe dope
For one thing what model heater is it?? If this unit has a mechanical water valve, the water valve may be clogged also.
Jan 15, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Water Heaters Logo
49 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
