Question about Brother MFC-3240C All-In-One InkJet Printer
MFC 3240C seems to dead
All the unit does is beep. will not scan, copy or spring. Have unplugged, etc...message says can't clean..refer to maintenance section of user guide
    President:
  • 2,306 Answers
Unable to clean means the ink absorber is full and you need to have the absorber box replaced and the counter reset at a shop. The job usually costs less than a hundred dollars, but the new mfc 490 is selling for about $129.00 with a one year warranty.
Posted on Oct 02, 2009
5 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Cannot scan an e-mail to send
OK I beleive you it is a valid product!!!!!!!!!!!
have you installed scanning software as well as print drivers?
Brother website get full software and driver package (under drivers) and install
Posted on Oct 28, 2007
SOURCE: mfc-3240c/lost maintenance guide
You can get both manuals at this site:
http://safemanuals.com/user-guide-instructions-owner-manual/BROTHER/MFC-3240C-_E
Posted on Jul 29, 2008
checkitright
  • 1362 Answers
SOURCE: Printer stopped printing
hre is the manual :
http://www.retrevo.com/support/Brother-640-Fax-Machines-manual/id/19095bh537/t/2/
Tnx, and please rate
Posted on Oct 02, 2008
cene765
  • 787 Answers
SOURCE: My Brother MFC-3240C printer says unable to clean
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 -defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 16, 2009
Brother MFC-3240C All-In-One InkJet Printer will not initiate when inserting a page to copy.
try cleaning the primary feed rollers with 99% alcohol. make sure mahine is unplugged and the rollers are dry prior to repluggin it in.
Feb 28, 2014 | Brother MFC-3240C All-In-One InkJet...
Unable to init.after period of none use
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Nov 23, 2009 | Brother MFC-3240C All-In-One InkJet...
My Brother MFC-3240C printer says unable to clean and to troubleshoot in user's guide but I can't access the guide RCT
Nov 16, 2009 | Brother MFC-3240C All-In-One InkJet...
Paper jam
im assuming you are using regular copy paper, is so fan the paper out before you put it in the printer and also check to see if the roller inside the printer are clean. they pull the paper threw the machine.
Jun 28, 2009 | Brother MFC-3240C All-In-One InkJet...
Unable to clean ... Brother MFC 3240C
Machine Error 46, Purged Ink Box Full
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An initial purge, for example, advances the purge counter by 187 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unusable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: unplug the unit, hold down the Menu/Set key, re-insert the power plug while holding down the Menu/Set key. The internal Machine Error Code will be displayed. Unplug and re-plug the unit again before continuing to the steps below.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the up arrow key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
May 27, 2008 | Brother MFC-3240C All-In-One InkJet...
How do you scan on the Brother MFC-3240c?
It scans it like a fax machine or a copier does, feeds the paper instead of pulling it from the tray.
Apr 26, 2008 | Brother MFC-3240C All-In-One InkJet...
Top Paper Feed Won't Work
Like a worn running shoes, the paper feed roller of the Automatic Document Feeder (ADF) have lost it's traction and has to be replaced or cleaned. Paper just slids and doesn't picked up properly without that little push. Professional servicers use a cleaner specifically designed for rubber rollers. However, YOU CAN get extra miles on it by dabbing a Q-tip in warm water and cleaning the paper feed roller on the ADF. Like all eletrical devices, the unit has to be turned off and unplugged before working on it. Take all precationary measures and goodluck.
Nov 29, 2007 | Brother MFC-3240C All-In-One InkJet...
Oct 01, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
