Question about Dell 1320c Laser Printer
My Dell 1320 C won't print...a yellow light if flashing next to the black inkdrop icon on the control panel on the printer..the ready data button is flashing..am I out of ink? emr
PABLOCSA
  • 1124 Answers
SOURCE: 924 message "printer is busy"
Take out the cartridges
disconnect printer from computer
Turn off the printer
On the computer cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot.
Reconnect printer (swap cables if not detected)
Insert the cartriges
Try printing again
Have a great day!
Let me know how it is going
Pablo :-)
Posted on Oct 20, 2008
  • 3 Answers
SOURCE: Dell 1700n Ready/Data light blinking (secondary fault)
Ok, try this--1.power off printer 2. open front door 3. press and hold continue and cancel buttons 4. power back on 5. wait until light sequence stops om error 6. power off and back on.
this resets factory defaults on the printer..
Posted on Dec 03, 2008
1alexh
  • 484 Answers
SOURCE: my Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
Posted on May 22, 2009
97F350diesel
  • 1326 Answers
SOURCE: PRINTER "OFFLINE" FROM PC CONTROL PANEL, PRINTER SCREEN READY
Make sure you have the ethernet cable plugged into the printer/network and is working properly. The toner replacement doesn't affect the network functions of the printer
Posted on Aug 06, 2009
kachi
  • 406 Answers
SOURCE: dell 1320 c yellow light on won't print changed
check paper jam.
Posted on Feb 03, 2010
How do I get a page count on my laserjet 1320?
You can see the the count in configuration page, to print configuration page do the following:
To print the configuration page from the printer, press GO for 5 seconds, until the yellow light comes on, when the printer is in the ready state....
Jun 20, 2013 | HP LaserJet 1320 Printer
Deskjet troubleshoot My HPdeskjet 5550 won't print.: My HPdeskjet 5550 won't print. The orange light is flashing
hi..........
In this error condition, the following light pattern displays on the product control panel and a message might display on the computer:
  • Print Cartridge status light : On
  • Resume light : Off
  • Power light : On
Figure 69: The Power light is on and the Print Cartridge light blinksc02645167.gif
    hpweb_1-2_minus.gif Causes
    • The cover on the product might be open.
    • There might be a problem with one or both cartridges.
hpweb_1-2_minus.gif Solutions Follow these solutions in the order presented to resolve the issue. Solution one: Close the top cover on the printer
  1. If the cover on the product is open, close it.
  2. Press the Resume button (c01219285.bmp ) to continue printing.
Solution two: Determine the cartridge issue When there is an issue with a cartridge, a yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is. Follow these steps to determine the cartridge issue, and then continue to the next section for solutions to resolve the issue.
  1. Open the top cover on the product. Wait for the carriage to move. The yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is.
  2. Look at the drawing and then find the icon in the following figure that matches the drawing. Each of these icons represents a different cartridge issue. Use the icons to determine the cartridge issue. Figure 70: Determine the cartridge issuec02645168.gif 1 - Tri-color Cartridge Problem icon 2 - Black Cartridge Problem icon 3 - Tri-color Cartridge Low-ink icon 4 - Black Cartridge Low-ink icon 5 - Cartridges OK icon
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP DeskJet 5550 InkJet Printer
HP4550 - 49.00FF service error
Turn off the RAM disk on the printer.
Follow these steps:
Troubleshooting steps
1.
Verify that the formatter light is blinking or steady. If the formatter is blinking, it is functioning properly and probably does not need to be replaced. If the formatter light is not blinking, proceed to Step 2.
2.
Turn off the printer and unplug the power cord.
3.
Remove the HP Jetdirect card, third-party device, hard disk, parallel cable, or IFR cable from the formatter if one is installed.
4.
If the error continues with accessories removed from the formatter, perform a cold reset on the printer. Ensure the HP Jetdirect card is not in the printer during a cold reset or the card settings will be changed back to default settings. To perform a cold reset, do the following:
1.
Turn on the printer.
2.
Watch the control panel.
3.
When the memory starts counting, press and hold the green (Select ) button.
4.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE .
6.
Press (Down Arrow ) button once. The control panel will display COLD RESET
7.
Press (Select ). The printer will perform a cold reset and then continue its power-on sequence.
5.
If the printer comes up to ready, print a Configuration page. If a 49 error occurs from printing internal pages, continue on to the next step.
6.
Turn the printer off and unplug the power cord.
7.
Remove the eight screws around the formatter.
8.
Remove the formatter. See Figure 1.
9.
Reseat the firmware and memory modules on the formatter. Check for any DIMMs that are non-HP and remove them. Non-HP DIMMs are not supported by HP and may cause this error. Replace with HP DIMMs, if necessary.
10.
Reseat the daughter (interconnect) board. The daughter board is connected to the formatter behind EIO slot #1. To release the daughter board, push in the black retaining tab underneath the formatter then lift up the one side of the daughter board.
11.
Reseat the daughter board.
12.
Install the formatter.
13.
Turn the printer on again.
14.
If it comes up to READY , print a configuration page. If a 49 error does not appear from printing internal pages, or at power up, continue to the next step.
15
Install the HP Jetdirect card and hard disk before installing the formatter. Verify that each device is properly seated.
16
Test any EIO devices, by turning off the printer, installing each device separately, and printing a Configuration page. Repeat for each EIO device.
17
If the 49 error occurs with any EIO device installed, replace that EIO device.
Oct 05, 2010 | Computers & Internet
Downloaded driver from HP. connected printer via
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
Dec 05, 2009 | HP LaserJet 2100tn Printer
How can I get a printout of the number of copies printed on my 1320?
Suggest the following as you are not able to connect through the tool box
a. press Go (the green button) for five seconds when the printer is in the ready state.
this will print the configuration page and then the supplies status page for the current toner in the printer.
The Supplies Status page provides information about the print cartridge that is installed in the printer, the amount of toner left in the print cartridge, and the number of pages and print jobs that have been processed. The Supplies Status page automatically prints when a Configuration page is printed from the control panel.
hope that helps
Sep 25, 2009 | HP LaserJet 1320 Printer
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
1. Press the green <Tick Symbol>(Select) button to continue.
2. Turn the printer off, and then turn the printer on.
3. If the error message returns, turn the printer off.
4. Perform a cold reset.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
5. If this message persists, contact an HP-authorized service or support provider.
Sep 22, 2009 | HP LaserJet 5500 Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
Solution:
Turn the printer off and then back on again.
If error returns, remove all print cartridges and turn off the printer.
Cold reset the printer:
When the memory starts counting, press and hold the green (Select) button.
Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
Wait for the printer prompt to install each print cartridge.
This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
Jan 15, 2009 | HP LaserJet 4600dn Color Printer
HP 1320 will not power up
There actually was a misfed sheet, hidden at the very bottom of the lower hinged back panel. The reason it was misfed was that this panel had somehow gone off one of its hinges. Ironically I did not discover the misfed sheet until I had taken the printer down from its shelf and turned it over to read the serial number to the extended warranty tech support guy.
Moral: Open every panel carefully, check for misalignment. These printers have flimsy plastic parts.
Dec 13, 2008 | HP LaserJet 1320 Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Dell 1320c Laser Printer Logo
187 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
