Question about Pitney Bowes Office Equipment & Supplies
Machine giving me a code machine error 78, offline
4 Suggested Answers
  • 82 Answers
SOURCE: PB 1630 fax machine
it sounds like a programming issue, the machine should be auto recieve mode to work properly. but please be more descriptive on make and model and when it gives you the code
mikey
Posted on Mar 16, 2008
leroyal
  • 2120 Answers
SOURCE: machine error 78 offline
You have a bad FUSER. There's nothing you can do. A dealer must replace the fuser.
Posted on Oct 26, 2008
  • 43 Answers
It means you need to replace the fuser. Depending on what model it is it may be cheaper to replace the fax.
Posted on Apr 20, 2009
What does a 77 error code on a Bernina sewing machine mean?
Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off. Sometimes the machines will give a false code and can be reset
that answer has been posted vk88
Mar 28, 2012 | Sewing Machines
GETTING MACHINE ERROR ERROR 78 , PRINTER NAME BROTHER MFC 8840D
Machine Error 78 indicates a mechanical malfunction of the Brother MFC-8840D. 78 represents the error number. You have to contact Brother Customer Service 1-877-BROTHER.
Dec 22, 2010 | Brother MFC-8840D All-In-One Laser Printer
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
Display says "L8" ???
Are you sure L8 ?
Likely I knowed about Error 78...
Machine error 76-78 are fuser errors. 95% of the time due to a sudden power loss like during a thunderstorm. The machine turns off for a brief second then back on. When this happens the machine likes to go read the fuser's temperature without waiting for it to warm up. It reads a low temperature and gives you the code. Most brothers service modes are entered by pressing Menu,*,2,8,6,4. Has to be done in a certain time frame so it might take a try or two. Once entered the machine will beep, the lights on the display will flash and it will read MAINTENANCE. Next enter 9,9 and the machine will reboot. That should fix the issue if not and your mechanically inclined I would pull out the fuser and check for continuity across the lamps and thermal fuses.
I hope helps.
Oct 06, 2010 | Office Equipment & Supplies
How do I fix a machine error 78 on my brother MFC 8300?
unfortunately that specific error is pointing to a problem with the thermistor. here is the error code from Brother:78 Heater thermistor harness disconnected or broken. - SOLUTION: REPLACE FUSER UNIT
HERE is a link to other error codes and possible solutions.
Aug 30, 2010 | Brother MFC 8300 Laser Printer
Will not receive fax Will not send fax Will not copy Has error Message 76 on monitor
Machine error 76 is a bad fuser lamp.Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
May 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Machine error 78
Apr 09, 2009 | Brother Office Equipment & Supplies
Machine error 78 offline
Jun 26, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
PB 1630 fax machine
mikey
Mar 13, 2008 | Office Equipment & Supplies
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Victorman
Victorman
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
