Question about MSI PM8M-V Motherboard
Problem whit audio front panel
Hi.I have a MSI PM8M3-V H (MS-7211 v4) (3 PCI, 1 AGP, 2 DDR DIMM, Audio, Video, LAN) motherboard is new but i don't no connect audio front panel wires.Headphone and microphone not working.Pleas help me.Tower is delux.color of wirew is:mic in doble(yellow),gnd black two wires,ear r doble wire(white)and ear l doble(green) and 9-pin motherboard front.Thank you.
mewms_14904
  • 1027 Answers
SOURCE: ddr and ddr dimm
To answer you there is no difference
DIMM= Dual In Line Memory Modual 64 bit transfer
Dimms replaced Simms when pentium ll came out.
DDR= Double Data Rate
Newer memory modules are DDR2 or DDR3
Older systems are DDR or SDRAM
All the systems use SDRAM DIMMS, DDR DIMMS,DDR2 DIMMS, DDR3 DIMMS.
Posted on Apr 17, 2008
ohms
  • 1879 Answers
SOURCE: K7VT4A-Pro Mobo
Greetings,
The motherboard will read 1GB DDR400 memory per slot only.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 19, 2008
Antipode
  • 51 Answers
SOURCE: Audio driver
This board has the Realtek AC'97 audio drivers.
For XP: http://www.softwarepatch.com/utilities/ac97.html
For Vista: http://www.softwarepatch.com/utilities/ac97-realtek-driver-vista.html
Posted on Apr 13, 2009
  • 1129 Answers
SOURCE: the video controller(VGA compatible) of MSI PM8M3
you can go to the companies web site and usually pick from the category "Tech Support" to get the latest driver updates.
Posted on Aug 02, 2009
brannfenix
  • 81 Answers
SOURCE: Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Posted on Aug 12, 2009
Testimonial: "thanks for reply.. I had installed it and PC booted but it was stucking too much..."
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
Jun 04, 2012 | MSI Computers & Internet
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
Motherboard Name MSI PM8M-V H (MS-7104 v2) (3
MSI PM8M-V is a VIA UniChrome P4M800-based, PC motherboard. Form Factor: Micro ATX. Compatible with Intel P IV and Celeron. Maximum Bus speed would be 800MHz. Maximum RAM Supported is 2GB.
If the specifications differ please inform me.
Thanks for contacting Fixya! Please rate the answer if it solves your problem.
Jun 05, 2010 | Computers & Internet
What type of motherboard for HP Compaq dc5700
The motherboard that you have is : yale-UL6E,
  • view the manual:
    yale_manual.pdf (300 KB)
  • micro-atx form factor
  • Intel Pentium 4 HT processor
  • Intel Celeron processor
  • Socket 478
  • 800/533/400 Mhz front side bus
  • Intel 865-PE chipset
  • 4 DDR-DIMM slots for single or dual channel configurations
  • supports PC2100 (266 Mhz), PC2700 (333 Mhz), PC3200 (400 Mhz) DIMM modules
  • graphics: uses AGP card only
  • audio: integrated AC97 audio
  • lan: integrated 10/100BT ethernet
  • 1 AGP 4x/8x slot
  • 3 PCI slots
  • 8 USB ports (2 headers for 4 possible front I/O, 4 on back I/O) *
  • 2 IEEE 1394 ports (1 for front I/O, 1 on back I/O)
  • connectors for front headphones and microphone
Dec 14, 2009 | HP Computers & Internet
How mutch RAM does "Motherboard MSI PM8M3-V (MS-7211 v1.x) Micro-ATX" supports
Spec sheet shows you can run 2GB of PC2700 DDR RAM (DDR-333), or PC3200 DDR RAM (DDR-400); http://www.superwarehouse.com/MSI_PM8M3-V_Micro_ATX_Pentium_4_Motherboard/PM8M3-V/ps/727805
MSI also provides a list of tested memory for the board;
http://www.msi.com/uploads/test_report/TR10_234.pdf
Hope you find this helpful!
Mike
Oct 12, 2009 | MSI PM8M3-V Motherboard
Where can i get fc micro star n1996 model ms-7211 audio driver
Hi mabellmk85,
You can find all the software and drivers for that board HERE.
Good Luck,
and don't forget to leave a rating,
Thanks
Mark
Sep 27, 2009 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
Audio driver
Apr 13, 2009 | MSI PM8M3-V (7211010VPM8M3V) Motherboard
Need VIA AC'97 Enhanced Audio Controller Driver
You probably need the M/soft UAA drivers first download and install them
Then go to device drivers right click driver with yellow mark on it and upgrade driver should go on net and find and install driver
Oct 06, 2008 | Computers & Internet
MSI PM8M-V Motherboard Logo
311 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
